Need help with the window misalignment TSB!
Old Dec 20, 2007 | 07:29 PM
all_Bran's Avatar
Default Need help with the window misalignment TSB!
Please give me a hand, I'm desperate:
https://www.crossfireforum.org/forum...ad.php?t=20472
Old Dec 21, 2007 | 02:22 AM
sonoronos's Avatar
Default Re: Need help with the window misalignment TSB!
all_bran,
Not sure what to say there is something seriously messed up with that window and it has to be FIXED TSB or NOT.
If you are asking for advice - FIX IT NOW
Old Dec 21, 2007 | 09:05 AM
all_Bran's Avatar
Hey. Thanks for the reply, but Fix It doesn't help me a lot what is it supposed to look like for the roadster? Can someone take a picture of their window AFTER the TSB was performed? How about a picture of a roadster that didn't need the TSB and worked fine from day 1?
Originally Posted by sonoronos
all_bran,
Old Dec 21, 2007 | 09:38 AM
XFiringInNC's Avatar
I'd say that regardless of what it's supposed to look like, yours is definitely not right. Take it in and let the dealership figure out whether it's related to the problem with the TSB. If it's not... you still need to get it fixed.
Old Dec 21, 2007 | 09:57 AM
all_Bran's Avatar
Hey. Thanks for the reply. I had it in the dealership. There is no more warranty so its not their responsibility anymore. They looked at it very closely, I was in there for an hour with them, and they couldn't duplicate the road noise on the highway So, they can't guarantee that the TSB will fix the problem because they can't duplicate it.
They said that the TSB could actually make it worse if the window doesn't need to be moved up.
That's why I'm looking for other peoples pictures to give me an idea of what is normal.
Old Dec 21, 2007 | 10:00 AM
krafty3068's Avatar
I have a 2005 coupe that has the driver's side door misaligned. With this car, all my dealership cared about was that the window operated and gave it back to me. But my driver's side window sticks out slightly beyond the weatherstripping compared to my passenger's side window is totally sunk beneath the weatherstripping. I ended up moving the driver's side window on my own with the help of a thread from this forum.
Old Dec 21, 2007 | 12:44 PM
all_Bran's Avatar
Any pics of the before & after? I'm How does it relate to the pics I have in the thread?
Old Dec 22, 2007 | 02:24 PM
krafty3068's Avatar
I guess the only relation I see between our cases is the wind noise and a slight gap between the weatherstripping and the window. The gap for me was along the back of the window and not the top. It is easy to change the angle of the window and to adjust the back of the window. From adjusting the window I get less water entering the channel built into the weatherstripping when washing it, however the wind noise is pretty much the same. Sorry, but I didn't take any picutures during the process.
Old Dec 22, 2007 | 03:43 PM
robby363's Avatar
This TSB sounds like your problem but the other side.
Old Dec 22, 2007 | 05:14 PM
all_Bran's Avatar
Man, that really does sound like it... But my window doesn't come in contact with the roof. Do they mean that little lip that comes down on the convertible top? I don't think the glass hits that when opening/closing the door.
Old Dec 23, 2007 | 01:06 AM
robby363's Avatar
I think it's a common problem with these cars coupes and convertibles I get wind noise from the pass. side I haven't had it fixed yet because I haven't seen any water come in yet plus I don't want to risk them making it worse. In your case though I would have them look at it before it gets worse and causes more problems. I'm not sure about the TSB but they're pretty much the same in one way or another (the windows are f****d up). Take the pics that you posted with you so they can see the problem. Even if you have to pay $100 deductible it will be worth it in the long run especially if it's leaking water into your car.
Old Dec 23, 2007 | 11:50 AM
V-12's Avatar
if you want that fixed correctly, take it to an MB dealership- that top has everything in common with MB and nothing in common with Chrysler. They are very difficult to adjust correctly and require a factory trained tech. You will have to pay to have it done.
Old Dec 23, 2007 | 08:15 PM
all_Bran's Avatar
Thanks for the advice. I never would have thought to take it to an MB dealership.
I'll let you know what I find out!
Valk
Jul 12, 2021 09:49 PM
Nexxus
May 8, 2016 04:43 PM
Reliableron
Oct 17, 2015 10:19 PM
nataliefs
Oct 5, 2015 01:03 PM
BEATv1
Sep 10, 2015 12:58 PM
