Removing Windshield Wipers...
Old Jan 24, 2008 | 03:52 PM
Sidez's Avatar
Default Removing Windshield Wipers...
Hello another question by me again.. I can prolly figure this out on my own, but I would like to ask because that usually leads to me breaking something heh..
I need to remove my windsheild wipers and I am not talking about just the blades i am talking about the full arms.. I poped the hood and saw that they were attached by 1 bolt each but after looseing and removing those bolts the wipers would not budge.. am I not pulling to hard or do I have unscrew something in the bottom? Is it more complicated than I am making it sound?
Thanks in advance
-Sidez
Old Jan 24, 2008 | 04:01 PM
Shawnkey's Avatar
Default Re: Removing WindSheild Wipers..
remove the two 15mm nuts, grab the blade and shake vilontley to and fro, while pulling up.
Old Jan 24, 2008 | 04:13 PM
Sidez's Avatar
thanks
I guess I have to really shake violently cause that thing is TIGHT TIGHT TIGHT...
Old Jan 24, 2008 | 04:27 PM
Shawnkey's Avatar
grab where the blade meets the arm, so you dont bend the blade
Old Jan 24, 2008 | 04:50 PM
robby363's Avatar
A battery terminal puller or a small gear puller would be the best thing to use to remove them.
Old Jan 24, 2008 | 04:55 PM
Sidez's Avatar
it feels as if they are screwed in from bottom as well... I feel as if i shake and pull any more violently somehting is going to break.. and at the pace I am pulling I dont feel it moving up at all..
Old Jan 24, 2008 | 05:07 PM
Sidez's Avatar
dont have eaither of those
Old Jan 24, 2008 | 05:21 PM
robby363's Avatar
Default Re: Removing Windsheild Wipers...
If I were you I'd go to auto zone or a parts store and get one of these so you don't damage anything. http://www.autozone.com/selectedZip,.../selectZip.htm
Old Jan 24, 2008 | 05:22 PM
Sidez's Avatar
alright sounds good Ill check for it tomorrow... and let you guys know..
Old Jan 24, 2008 | 05:23 PM
robby363's Avatar
Why do you have to remove them
Old Jan 24, 2008 | 08:22 PM
Sidez's Avatar
I am doing some modifications I will post about pretty soon and need them removed...
Old Jan 25, 2008 | 04:50 AM
spensley's Avatar
Don't take this the wrong way, but...
I've read this thread- from your first post to your last (just before my reply).
You say you usually end up breaking things.
You say you can't remove the windshield wipers.
You say you're going to do some mods.
I CAN'T WAIT TO SEE THE RESULTS!!!
Woo hoo... what tools are you using - a can opener and a hammer?
Old Jan 25, 2008 | 05:04 AM
robby363's Avatar
I hope he doesn't use one of these...just kidding. http://www.harborfreight.com/cpi/cta...emnumber=95666
Old Jan 25, 2008 | 06:19 AM
I can't immagine what mod you would be doing to windshield wipers. But you are aware that the driver's side and passinger's side are two different lengths?
Chris L.'s Avatar
Heston....Planet of the Apes....."get your hands off her you damn dirty apes!".
Old Jan 25, 2008 | 08:57 AM
Sidez's Avatar
interesting post... you had a bad day or something? no seriously why even bother if you got no input to other than negativety... mind you not everyone on the forums does work personally to their vehicles far from it, but with the crossfire, I decided to take things into my own hands.. only to be mocked? what for?
I never told you to be excited about a mod I am doing.. and if you can't wait to see results ill try to post some pictures as soon as I can... and as for the tools I am using.. well average home owner tools is what I have .. chainsaw, screw driver, can opener, hammer, well you get the idea...
Hm.. even with the battery puller it is not moving..
Old Jan 25, 2008 | 09:29 AM
spensley's Avatar
On the contrary - I'm having a great day.
As my first line read...
Which you obviously do, and have zero sense of humor.
You left yourself wide open for a quick light hearted jab with your own statements.
I have no problems with anybody doing anything to their car.
I do, and am planning on doing things to mine, and there will be write-ups, and I will expect criticism and perhaps mockery, but I will not start crying.
It's my car, not yours/vice versa - which takes me back to the sentance starting with... 'I have no problems...'
If you haven't already tried...
Spray some WD40 or similar substance onto where the wiper arm assembly is attached to the spline on the motor.
If you are trying to remove the wiper blade assembly with the blade still on the windshield in the down position, trying hinging the blade off the windshield and trying to remove it then, even though the spring is not strong, it is strong enough to make it bind on the spline.
Old Jan 25, 2008 | 10:32 AM
Sidez's Avatar
i had a friend just do it for me pretty halarious he took it off.. as easy as I open a can of ice tea.. than he put it back and showed me how to do it and again I was unable to do it... heh
Old Jun 20, 2008 | 06:29 PM
NJCrossfire05's Avatar
12mm to remove nuts off of wipers
4” gear puller from pep boys $24.00 to remove wiper arms
I was worried about attaching the wiper arms but they just pop on and tighten up with the 12mm nut. No sweat, however you must use a gear puller to remove them! Do not try to just pull them off it won’t work.
Search alarm chirp and you will find my pictures of what you need.
Old Jun 20, 2008 | 09:14 PM
ppro's Avatar
Default Re: Removing Windshield Wipers...
WARNING: THE WINDSHIELD WIPER MECHANISM CAN PINCH, CRUSH OR, IN EXTREME CASES, EVEN
SEVER EXTREMITIES. ALWAYS REMOVE THE IGNITION KEY WHEN WORKING ON WINDSHIELD WIPER
MECHANISM.
1. Open the hood, then press the hood prop release button on the hood prop outer sleeve to extend the hood prop
fully (1).
2. Lift the wiper arm (2) to its over-center position.
3. Carefully pry the plastic nut cap (5) off of the pivot end of the wiper arm (2).
4. Remove the wiper arm attachment nut (4) from the wiper pivot shaft (3).
5. Use a suitable battery terminal puller to disengage the wiper arm from the wiper pivot shaft tapered splines.
6. Remove the wiper arm pivot end from the wiper pivot shaft (3).
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
williammt
Sep 6, 2015 11:23 AM
