LED electrical issue
Old Feb 21, 2008 | 09:22 PM
The_Cohort's Avatar
Question LED electrical issue
Recently I installed blue LEDs in the cabin and everything looks good. However, I noticed tonight the dome ones remain extremely dimly lit when not on and when I roll the windows down they flick on for an instant along with the truck light. Any ideas?
Blue Skies
Old Feb 21, 2008 | 09:31 PM
NeverEnough's Avatar
Default Re: LED electrical issue
Odd...
Would like to know myself.
Old Feb 21, 2008 | 10:45 PM
DanielNTX's Avatar
Yeah I've had the same issue, there's a feedback current that turns on the dome light when the power window switches are used. It's not annoying enough for me to fix it.
Old Feb 22, 2008 | 03:49 AM
Sarx's Avatar
Got pics???
Old Feb 22, 2008 | 08:09 AM
DanielNTX's Avatar
Originally Posted by Sarx
Got pics???
It's just a brief flash. No pics. I think it's always been there. The reason why traditional bulbs didn't light up is because it required more power to do so. LED's don't require as much so it does it.
Old Feb 22, 2008 | 10:01 AM
nox1s's Avatar
I don't think mine does this ??
Old Feb 22, 2008 | 11:06 AM
The_Cohort's Avatar
Before I ask if another question, allow me to quallify my experience. I dropped EE 231, EE for Engineers, and had to take EE 215, EE for non-engineers. Ok now then, since the the LEDs require less power would it be possible to add a resistor in the circuit before the first LED to prevent them from lighting up?
Old Feb 22, 2008 | 11:53 AM
Chris2806126's Avatar
Putting the resister in front (in serries) would drop the voltage to the LED. Put one across (in parrallel) would increase the current required to light the LED. What resistance and wattage? I'm not that smart today. Good luck....
Old Feb 22, 2008 | 12:03 PM
Idaho's Avatar
The_Cohort,
A resister may work but I was personally thinking that zenner diode may be a better method. I would use one that has a breakdown voltage slightly lower then the triggering threshold of your LEDs. You may have to experiment a little since I haven't' worked with zenners for year where they actually start to avalanche; above or below the target voltage.
Old Feb 22, 2008 | 12:17 PM
Idaho's Avatar
Chris:
Putting a resistor in parallel will drop the over all resistance of the load that the battery source sees but there will still be 12V across the LED package. Now I am not sure exactly how the LED package is configured; whether all the LEDs are in parallel with a single current limiting resistor or whether each LED has its' own current limiting resistor. IMO series would be the preferred method over parallel to reduce the current flow through the LEDs.
Old Feb 22, 2008 | 06:05 PM
old man's Avatar
had the same problems with the leds went to the pia bulbs they work fine
PNA
Nov 12, 2020 04:44 PM
northwest_crossfire
May 30, 2016 05:19 PM
MiamiTVR
Jan 30, 2016 02:15 PM
Sep 13, 2015 02:12 AM
RiderJC
Sep 7, 2015 11:19 PM
