TPMS and BAS/ESP light on
Old Aug 2, 2008 | 04:26 PM
racermp's Avatar
Default TPMS and BAS/ESP light on
ok so, car hit a curb (bought i that way) and the stock wheels were all bent,
i bought a set of wheels and installed them on my crossfire, the tirepressure is set to 40 all around. but the tpms light wown't go away.
do i have to do anything to tell the computer i have new sensors or is it a universal item?
and the bas/esp light
i tried turning on the car, turning the steering all the way to the left, then to the right, then center and restart the car, it doesn't reset it. the battery was disconnected. what should i do?
thanks all for any imput
Old Aug 2, 2008 | 06:04 PM
patpur's Avatar
Senior Member/Moderator
Default Re: TPMS and BAS/ESP light on
Probably have to have the TPMS reset at the dealer. As for the ESP/Bas light try a search on BAS/ESP been an issue around here the past few weeks. I've been lucky mine reset both times its come on but it took a few hours before it did so. I think I also read here that tire pressure was an issue with the ESP/BAS light in some cases. I'd start with getting that reset and see where that leads you.
Pat
Old Aug 2, 2008 | 06:11 PM
maxcichon's Avatar
One cute little quirk with the TPMS sensors is that they are position sensitive-if one came from, say, the right front and it then gets installed on the left rear, the light comes on and a trip to the dealer!
At least that's what I understand.
Old Aug 2, 2008 | 07:14 PM
CrossfireLTD's Avatar
Cool Re: TPMS and BAS/ESP light on
Plus.......you have way to much air in the tires if you are using the OEM/stock fitment. The pressure should be 32psi front and 33psi in the rear, TPMS will trigger when there is a 25% difference in psi this includes over inflation also.
Old Aug 2, 2008 | 10:50 PM
racermp's Avatar
hey thanks all. yea the tire shop said 3 were at 40, one was 20. so he put it to 40. and i drove it 10 or so miles. i'm gonna lower them to 32/33 tom. i'll let you guys know what happens.
the wheels w/ tires are stocks, i bought them used to they came with tires and all. i'm not sure if the sensors were moved around.
thanks for the info all. i'll keep yall updated
RedRover
May 26, 2021 02:09 PM
xfClifford
27
Nov 10, 2015 10:08 PM
Bayukbros
Aug 28, 2015 08:59 AM
2004_
Jul 11, 2015 03:14 PM
Blackout317
Jul 7, 2015 08:38 PM
