How in the F do you change the headlight bulb? Broken thumb edition.
Old Oct 17, 2008 | 12:49 PM
MAYAman's Avatar
Default How in the F do you change the headlight bulb? Broken thumb edition.
I have been trying now for an hour to get my drivers side low beam bulb out. There is a metal clip and then I tug on the bulb and it keeps running into the metal clip. Now its just hanging there and I can't get it back in or out. Nice design.
Old Oct 17, 2008 | 01:13 PM
robby363's Avatar
Default Re: How in the F do you change the headlight bulb? Broken thumb edition.
Disconnect the the plug from the bulb first then push the bottom of clip in a little and move it to the left or right depends which light it is. Then when you unclip it you can lift it up out of the way to remove the bulb. It might be easier if you have a long curved pair of needle nose pliers. It makes it a lot easier than trying to do it with your fingers.
Old Oct 17, 2008 | 01:16 PM
As RayRich said at our last DFWXfire GTG, get a dental mirror and needle nose pliers. He read about it here in the forum and went to Walmart and got um. Popped it on in about ten seconds. Good luck!
Old Oct 17, 2008 | 01:33 PM
MAYAman's Avatar
The part with the wires won't seperate from the bulb.
Holy crap I think I'm stuck with one headlight. It won't come loose, I tried pliers and I don't have a dental mirror.....
Halp
Old Oct 17, 2008 | 01:39 PM
robby363's Avatar
If it's the first time the plug has been removed it's on there tight. It will come off if you wiggle and pull on it hard at the same time.
Old Oct 17, 2008 | 01:43 PM
MAYAman's Avatar
I pulled on it so hard that the entire housing seems to have come loose from the assembly!!!! I won't budge! DAMN IT TO HELLL!
Old Oct 17, 2008 | 08:50 PM
nox1s's Avatar
Yeah, grab the plastic with your hands and wiggle / pull as hard as you can.. the harness HAS to come off...
Then push in the metal tab and push to the side, then pull the metal spring up and remove the bulb..
Old Oct 18, 2008 | 04:27 AM
crossfirefrank's Avatar
If you think that one is hard wait till you have to change the one on the passenger side.
Old Oct 18, 2008 | 05:06 AM
mrphotoman's Avatar
lol this is something to really look forward to.
Old Oct 18, 2008 | 07:10 AM
manisusmc's Avatar
i went to the dealer and paid 20 bucks to get them to change them well worth every f,ing penny
Old Oct 18, 2008 | 07:59 AM
I have to agree. Not worth doing yourself after reading the threads of how hard it can be to do and the risk of breaking that clip. That's the only reason I didn't do my own HIDs.
Old Oct 19, 2008 | 02:37 PM
Cruiser's Avatar
If you go to the dealer to have them change the bulbs, like I have 4 times, and I forgot this last time......make sure that you have them point the car into a dark wall and look how they have the one they just put in pointing. I have to go back again sigh...and have them lower the one they just installed. Sure is a waist of my time again! I can see an owl in a tree at night, it points that high in the sky, lol
Old Oct 22, 2008 | 08:22 AM
Montana Crossfire's Avatar
Done it twice on both the Crossfires. Fourth time is no easier but REFUSE to take it in just for the principle of the thing. I have kinda come to accept it as a sword in a stone, a Wterloo or maybe a sqare peg in a round hole kind a thing.
What's really nice is when you get them back in but first time you drive down the highway at night you discover they're not in the socket correctly so you get to do them again. Oh well I guess it's no different than marrage to some...
Mike
Old Oct 22, 2008 | 08:23 AM
rodimus's Avatar
It was driving me nuts too and ended up taking it to the dealer.
Of course my stealership charged me a 100 bucks. I greatly despise them more and more everyday.
Old Oct 22, 2008 | 10:45 AM
nox1s's Avatar
This could be two things. MOST LIKELY the bulb is not seated right... not the headlight aiming...
Anyways, I don't have that much of a problem anymore.. I can do it within a few minutes.. Anyone near sterling heights michigan want to pay me to change the bulbs for them?!!?
(Also accepting home cooked meals)
Old Feb 13, 2010 | 10:44 AM
naudi90's Avatar
I now have the pleasure of fixing my improperly seated bulbs.
I noticed that the drivers side low beams did not even have a metal clip in there! It must have been bouncing around while driving. I'm stealing the high beam clip as its not as important.
Anyone know where to get another clip(s)?
Old Feb 13, 2010 | 09:11 PM
MikeR's Avatar
I found that if you take the headlights out, or at least un-mount them, it is really easy. It's only 4 bolts that are a lot easier to get too. (maybe the bolt up top by the grille for the bumper too).
I would also rather take the bumper of and the headlights out than fight with them the way they have them mounted if I couldnt do it by un-mounting the headlight.
Old Feb 13, 2010 | 10:04 PM
corfire's Avatar
See my posts in the following thread. That should help. It really isn't that hard if you use a mirror and needlenose pliers. Should take 30-60 minutes or so to change all of them. I found it easier to totally remove the clip, but you do run the risk of dropping them. Some say you wiggle the plug to get it off. I would use the word 'pry'. It can take quite a bit of force to get it off. Almost a twisting motiion.
https://www.crossfireforum.org/forum...-question.html
maxcichon
Jul 8, 2016 08:28 AM
gp1200x
Dec 6, 2015 12:59 PM
ardenian
19
Nov 21, 2015 12:00 PM
Tp'sfury
Aug 13, 2015 08:20 PM
xfClifford
Aug 3, 2015 11:03 PM
