Crossfire Inside interior issue
Old Jul 30, 2009 | 11:28 AM
FJMieses's Avatar
Default Crossfire Inside interior issue
Im gonna do the best i can to explain this. Inside my vehicle, I have an issue. Because of the hot florida sun, the top of the inside is completly coming off. Its hanging down on the passengers side and I dont know what to do? Any suggestions would help.Thanks guys, you guys are always a big HELP!
Old Jul 30, 2009 | 11:45 AM
H82BL8's Avatar
Default Re: Crossfire Inside interior issue
Here are a few past posts, I found these in a couple minutes. There are probably more. Use the search field - (top menu bar, third from the right) and you will find everything you need here. Hope this helps, happy reading.
https://www.crossfireforum.org/forum...xed-cheap.html
https://www.crossfireforum.org/forum...headliner.html
https://www.crossfireforum.org/forum...r-falling.html
https://www.crossfireforum.org/forum...ed-anyone.html
https://www.crossfireforum.org/forum...placement.html
https://www.crossfireforum.org/forum...r-out-car.html
https://www.crossfireforum.org/forum...r-peeling.html
Old Jul 30, 2009 | 03:06 PM
blackcrossfire07's Avatar
Don't panic. This is a common problem with these cars! Most of the headliners drop so it is only a matter of time. Unfortunetly now it is your time.
I had this problem in the hot south Texas sun. Cost me about 120 dollars to get a new headliner from a guy in the business (don't buy a new factory part). He had been in business 40 years doing headliners and took him a couple hours to replace with new material. He said they must have used bad glue and didn't wrap it properly from the factory. All it takes is a little heat and humidity to start drying out the glue.
I suggest finding someone good to replace it. Then you will never have the problem again because it will be done right. Don't spend hundreds for a brand new OEM part because it is probably the same poor quality that the car came with.
amatxcrossfire
Aug 15, 2015 01:28 PM
WindRestrictor
Jun 16, 2015 12:18 PM
46Chiefpilot
Jun 14, 2015 03:17 AM
MJPowers
Jun 8, 2015 02:34 AM
gobraves423
Jun 6, 2015 07:03 PM
