Reverse Problem!!?? (6 sp manual)
Old Mar 15, 2010 | 01:49 AM
Crossfire725's Avatar
Default Reverse Problem!!?? (6 sp manual)
when i back out of my driveway and have it in neutral and start rooling down my driveway. cause its a pretty big slope my cars just goes but when i am rolling and try to through in it reverse gears grind real bag an wont let you put it in reverse until car comes to complete stop. normal or no?
Old Mar 15, 2010 | 01:55 AM
samer2thamer's Avatar
Default Re: Reverse Problem!!?? (6 sp manual)
yea this completly normal with all manual tranmissions
Old Mar 15, 2010 | 09:55 AM
Infinite's Avatar
wow... really?
someone really just asked that.
Old Mar 15, 2010 | 11:03 AM
Musclefan21's Avatar
with reverse, that is how it should be. always engage while it is stopped.
Old Mar 15, 2010 | 02:33 PM
Chris2806126's Avatar
Owners manual say that even reverse has a synco.
From the service manual......
The manual transmission is a fully synchronized two-shaft transmission with six forward gears and one reverse gear. The 6th gear is used to save fuel and reduce engine speed. The manual transmission is equipped with a
conventional dry clutch with automatic wear adjuster which is operated by a central clutch operator. The transmission is maintenance-free and has a permanent oil fill. A precise and light shift with short shifting travels is achieved by the following measures:
²
Transmission of the shift lever movement to the transmission by the shift rod and control cable
²
Central shift shaft supported on needle bearings
²
Multiple-cone synchronization in 1st, 2nd, 3rd and 4th gear
² Fully-synchronized reverse gear
Old Mar 15, 2010 | 02:39 PM
Bazzer's Avatar
²
²
²
Regardless of what the manual says, think of whats happening mechanically. When rolling backwards your output side of the transmission is rotating in the opposite direction to the input side (engine input shaft).
Therefore have some mechanical sympathy and engadge reverse with the vehicle at rest.
Old Mar 15, 2010 | 02:42 PM
Big Al's Avatar
²
²
²
Been driving stick shift cars, and big rig trucks for 55 years,respectfully, and the one thing you learn first off=you always shift into reverse, and first gear from a complete stop, in a car, trucks differ in some ways
Old Mar 15, 2010 | 03:14 PM
I will agree with you, that's the right thing to do. But I have had a couple of occurences where I've been rolling backwards and shifted into reverse. No grind from the gear set I have heard....(Yoda)
Old Mar 15, 2010 | 04:02 PM
If you happen to have the gears spinning just right, maybe, but normaly there would be an interference just because of the ratios involved. It is easier mechanicaly to enter any gear but reverse in the situation. In many older trannys, if you do this, you can blow the master cluster.
Reverse, always done at rest, full stop.
roadster with a stick
Old Mar 16, 2010 | 02:50 PM
thank you all
2004_
Jul 9, 2025 12:39 AM
massanu
Feb 20, 2019 07:06 PM
onehundred80
Aug 12, 2015 03:08 PM
55chevy
Jul 20, 2015 03:08 PM
66L72M21
Jul 15, 2015 04:23 PM
