Looking for Multifunction Tool
Old Mar 15, 2010 | 02:34 PM
medenney's Avatar
Question Looking for Multifunction Tool
Just contacted local Chrysler Dealer, gave me a quote for 109.00 dollars for this tool. Any suggestions where I can find one more reasonable? (local MB dealer not helpful)
Old Mar 15, 2010 | 03:40 PM
Stargazer's Avatar
Default Re: Looking for Multifunction Tool
Here are some comments that were posted a while back....
<https://www.crossfireforum.org/forum/crossfire-roadster/39718-multifunction-tool.html>.....it seems as though E-bay is the way to go.
Good luck.
Old Mar 15, 2010 | 06:39 PM
GDC-SRT's Avatar
You have come to the right place!
There are plenty of us multifunction tools here.
Old Mar 15, 2010 | 07:17 PM
bmorgan's Avatar
And 32Krazy! is the ring leader.
Old Mar 16, 2010 | 08:18 PM
If you can cut and file one from metal, here's the sizes, it's .135 thick, 1/8" is close enough.
Here are the two variations I have had, I gave the second one away.
If you are really lucky, you may find yours in the pocket on the bulkhead between the seats, others have and it had been there since the car was new.
Old Mar 16, 2010 | 10:08 PM
Sandgrounder's Avatar
Great Stuff, will start forging one (at work ) tomorrow, should the sharp end be 40" or 4 mm
I assume a piece of 1/4 plate- 12 inch by 3 inch can be used to shape the multi tool
Dave
Old Mar 16, 2010 | 10:34 PM
Dave
Well the ink ran a bit and the .40" dim'n. looks like 40". The post says 1/8", I forgot it on the drawing, getting old.
One post on here has these made for $50 Canadian.
Heck $50 gets my original.
Old Mar 17, 2010 | 09:44 PM
50 for the sketch or the tool ?
1st dibs on the tool,
Old Mar 17, 2010 | 09:59 PM
Donny's Avatar
I just had a local make me one. Cost me $40.
Old Aug 19, 2014 | 02:52 PM
angelomd's Avatar
Does anyone know the part number for the multifunction tool. Just bought a 2005 Limited Convertible and cannot find the tool in the car.
Old Aug 19, 2014 | 03:01 PM
Send a PM to Mrmiata, he has some that he had made up for the forum members.
also, have a look at the video that pizzaguy did :
https://www.crossfireforum.org/forum...operation.html
Old Aug 19, 2014 | 04:38 PM
Chris L.'s Avatar
Send me a check for $20.00 I'll mail you my extra.
Down to only one XF now.
Old Aug 19, 2014 | 05:28 PM
deltacrossfirebob's Avatar
go to mrmiata!!!!!!!!
he did a GREAT job on mine and others.
Old Aug 19, 2014 | 11:20 PM
Chris L.'s Avatar
Does anyone know for sure that the tool for the convertible is identical to the tool that came with the coupe?
Old Aug 20, 2014 | 09:59 AM
Mrmiata's Avatar
My 04 coupe..came with wrench.. Wife's 05 roadster .. came with wrench.. identical.
Old Aug 20, 2014 | 10:10 AM
These are the shapes of the tools that came with the Crossfire, at least the two that I have had.
Top is Chrysler part #5140795AA
or Mercedes part #A 193 899 02 80
Bottom is Chrysler part #5127223AA or Mercedes part #A 193 899 03 80
Also attached is the drawing of the CLK tool, it has the 6mm Allen key attached to it. As put on the forum by Top Hydraulics.
Old Aug 20, 2014 | 11:30 AM
Chris L.'s Avatar
Thanks.......mailing my extra to Angelomd above.....he's got a roadster....should work OK.
Old Jan 18, 2015 | 07:24 AM
chiko's Avatar
My new to me roadster did not come with one. I confirmed each 10mm boxend wrench that I have worked OK for opening the decklid and lifting the top. It did not have to be especially thin to work though the slot makes it look like it does. I had a longer and thinner than average SnapOn 10mm that does work better so I will store that in the cab along with a right-sized screwdriver. Thanks for the YouTube video. I used that and could not find a position that required a special offset for the wrench. Every position worked fine.
Old Jan 18, 2015 | 09:21 AM
This makes even more sense:
A single tool that combines the 10 MM for the tonneau, and the 6 mm hex for the bow lock -
Search SiteSearch Key - 2088990080 - KEY - ES#1746403
syfi
Mar 28, 2026 04:14 PM
rampntlion
21
Feb 11, 2019 08:18 AM
smokey847
Nov 12, 2015 11:54 PM
81's
Sep 13, 2015 04:34 PM
MAXIMUM
Aug 4, 2015 11:04 PM
