mysterious leak
Old Apr 17, 2010 | 10:26 PM
Irishman8415's Avatar
Default mysterious leak
i have a blaze red 2004 base. i put it away for winter cleaned and prepped NO LEAKS EVER 25xxx miles... well my father decided to take it out for a cruise one last time and put it away, next time i went north i noticed trans fluid under neath. problem is its not leaking now, no check lights, runs and sounds perfect! any way to check fluidlevel? any ideas? dont want to put it back on the road if there might be something seriously wrong with her.
Any help greatly appreciated
Old Apr 17, 2010 | 11:02 PM
maxcichon's Avatar
Default Re: mysterious leak
Lots of folks have had this problem. An electrical feedthrough fails and leaks either it's fixed free(?) or there is a DIY written up by Waldig to -do it yourself.
TBS: 30-Mar-06 - E19 - Campaign - Cooling Fan and or Motor Assembly Replacement
TBS: 1-Apr-04 - D11 - Campaign - Radiator Hose Inspection and or Positioning
TBS: 23-May-03 - 24-003-03 - Air Conditioning - System Sealer Usage Prohibition
TBS: 7-May-05 - 21-002-05A - Auto Trans - NAG1 Fluid Weepage and or Leaks
TBS: 26-Jul-05 - 23-035-05 - Body - Circular and or Ring Marks on Glass
TBS: 18-Oct-05 - 23-042-05 - Body - Convertible Top Deck Lid Malfunctions
TBS: 2-Aug-04 - 23-030-04 - Body - Convertible Top Inoperative
TBS: 13-Dec-05 - 23-019-05A - Body - Convertible Top is Hard to Close
TBS: 18-Oct-04 - 23-042-04 - Body - Deck Lid Won't Open and or Convertible Top Inop.
TBS: 11-Nov-04 - 23-047-04 - Body - Door Mirror Wind Noise
TBS: 6-Dec-04 - 23-051-04 - Body - Liftgate Bumper Won't Tighten
TBS: 5-Feb-05 - 08-009-05 - Body - Pneumatic Power Lock Repair Kit
TBS: 8-Jan-05 - 23-001-05 - Body - Popping Noise From Side Window Area
TBS: 25-May-04 - 23-019-04 - Body - Rattling From Liftgate Area
TBS: 5-Sep-04 - 23-040-04 - Body - Rear Spoiler Parts and or Service Procedures
TBS: 29-Jul-06 - 23-032-06 - Body - Rear Spoiler Service Parts and Procedures
TBS: 5-Jul-04 - 23-025-04 - Body - Squeak and or Creak Noise From Rear Spoiler
TBS: 26-Oct-05 - 23-051-05 - Body - Tonneau Cover Rub Strip Wrinkled
TBS: 17-Oct-03 - 23-023-03 - Body - Wind Noise From Door Mirrors
TBS: 4-May-04 - 23-014-04 - Body - Wind Noise From Top of Door
TBS: 28-Jan-05 - 23-004-05 - Body - Window Glass Misaligned and or Contacts Roof
TBS: 21-Oct-06 - 23-047-06 - Body - Windshield Crack Diagnosis
TBS: 13-Jun-03 - 03-018-03 - Electrical - Systems Operation and or Features
TBS: 5-Jul-04 - 18-030-04 - Engine Control - MIL ON, Multiple Misfire DTCs
TBS: 25-Aug-06 - 08-030-06A - Engine Control - PCM Initialization Procedure
TBS: 20-Oct-05 - 18-037-05 - Engine Controls - Flash Programming Failure Recovery
TBS: 18-Jan-06 - 08-003-06 - Instruments - Cluster Initialization Procedure
TBS: 9-Mar-05 - 23-016-05 - Interior - Cup Holder Broken and or Inoperative
TBS: 10-Nov-06 - 23-036-06A - Interior - Interior Door Handle Replacement
TBS: 2-Sep-04 - 08-030-04 - Keyless Entry - Transmitters Inoperative
TBS: 13-Jan-05 - 08-002-05 - Lighting - Condensation in Headlamps
TBS: 9-Mar-04 - 21-002-04 - Manual Trans - First Gear Disengages During Normal Acceleration
TBS: 6-Jan-05 - 21-001-05 - Manual Trans - Gear Grind Sound When Shifting
TBS: 30-Jul-04 - 08-027-04 - Safety Systems - Inadvertent Damage and or Disabling
TBS: 29-Aug-03 - 19-005-03 - Steering - Power Steering Fluid Usage
TBS: 16-Dec-04 - 02-009-04 - Suspension - Front End Squeaking Sound
TBS: 4-Oct-06 - 22-004-06 - Tire Pressure Monitor - System Information
TBS: 1-Dec-05 - 22-001-05 - Wheels - Caring for Chrome Wheels
TBS: 8-Mar-06 - 23-014-06 - Wipers and or Washers - Wipers Smear or Streak Windshield
Old Apr 17, 2010 | 11:08 PM
Blast Chamber's Avatar
I just replaced my leaking connector shell today. It was fairly easy using Waldig's instructions. While I was under there I also dropped the pan and replaced the filter, pan gasket, and 116 ounces of ATF. I bought a special dipstick on eBay, but it probably isn't necessary if you just capture the fluid and put the same amount back in. Or, you can use a long ziptie which is what others have done on the forum.
https://www.crossfireforum.org/forum...-ta-daaaa.html
I bought the parts and fluid at the following site. The Adapter Plug Housing, which is the part that leaks, is available at the bottom of the page.
http://store.europarts-sd.com/transm...2002-2009.aspx
Old Apr 18, 2010 | 12:03 AM
maxcichon's Avatar
Transmission Fluid- OEM Fuchs-4 Liters 2002-2010
Where in Wisco are you? I'm from Stoughton and moved to Alabama 7 years ago.
Old Apr 18, 2010 | 07:39 AM
I'm in Beaver Dam, about 40 miles NE of Stoughton.
Old Apr 18, 2010 | 10:22 AM
great snowmobile racing.....lol.....been there, done that....now, I am old and don't like the cold so much....welcome, and nice write up....
Old Apr 18, 2010 | 06:47 PM
maxcichon's Avatar
I'll let you know when the better half and I visit? Maybe we can hook up?
Old Apr 18, 2010 | 07:11 PM
Sure thing. I travel for business fairly often, but let me know!
Old Apr 19, 2010 | 02:12 AM
THANK YOU EVERYONE! next time im able to get up north to where she is stored ill have to replace the connector..
minimayhem
16
Aug 23, 2016 07:47 AM
Steven 4190
Nov 25, 2015 10:12 AM
debradegiovanni
Sep 27, 2015 09:39 AM
RacerXofFL
Sep 15, 2015 05:00 PM
williammt
Sep 6, 2015 11:23 AM
