Turn signals suddenly stop working...
Old Feb 28, 2012 | 01:06 PM
mariontr's Avatar
Talking Re: Turn signals suddenly stop working...
Originally Posted by Infelice
I've had the same issue all Winter with my indicators. When I start the engine in the morning they don't work but my hazards do, and the bulb out warning light is on. The indicator stick has been replaced to a costly tune of £350, and the issue is still there.
Over the past 2 months I have noticed the following:
Once my engine heats up to normal temperature, the bulb out warning light goes off and the indicators work again.
As I am driving, if I get the timing just right, I turn the indicators on and then hit the dashboard where the bulb warning light is. This makes the bulb warning light turn off and the indicators work again.
I've also noticed that if my sidelights or headlights are on, I can wiggle the headlights switch and this tends to cut out the bulb warning light and make the indicators work.
I'm now saving to take my car in for a service and to have this fault looked at as there is obviously a short / wiring issue somewhere around the area of the bulb warning light.
PS - Apologies for my lack of technical knowledge, I'm a girl and don't know much about cars apart from I like driving
Hi Infelice, this is what ended up working for me. I took the bulb out of the engine compartment for the turn signals and their seems to be 2 or 3 contact points between the black plastic and the bulb. The contact were a little corroded, use some sand paper to sand them then took a needle nose pliers and pried gently the contacts on the black plastic enclosure so it was jutting out from the enclosure (not flush with it). Then put the enclosure with blub back into the opening in the engine compartment. This has worked for a couple of months now. Hope this helps you also.
Old Feb 28, 2012 | 02:03 PM
Default Re: Turn signals suddenly stop working...
The light switch is involved with the turn signals somehow. Your problem could lie there. The hazard lights are on the same switch circuit, do they work when you are having trouble?
Old Mar 9, 2012 | 08:45 AM
Infelice's Avatar
The hazards work fine and aren't influenced by the bulb out notification light. Whatever the issue is it seems to be getting worse, and now I can only get the bulb out warning light to go off if my engine is warm and I have headlights on !!!
Old Mar 9, 2012 | 10:18 PM
2fast's Avatar
I have read before that the blinkers and hazards are part of a single relay it happened to me and all i did was turn on the hazards for a minute and it unstuck the relay. it has worked for me for 2 years now and never happened again
Old Mar 12, 2012 | 07:44 AM
Infelice's Avatar
The hazard trick has never worked for my car, BUT.....
I took the fuse route this weekend. Pulled out fuse No 4, gave it a bit of a scrub with a nail file, cleaned it off and put it back. Bob's your uncle and the indicators now work and have done for the past 24 hours !
Unfortunately the problem has moved to the break lights. Now my bulb out warning light comes on when I press the breaks for the first time after starting the engine, and my driver side break light doesn't work. I've checked and replaced the bulb (just to be sure) and the damn thing refuses to work.
I swear if my car didn't have that bulb out warning light then it would probably be fine !!!
Old Jan 26, 2015 | 02:54 AM
ibows1's Avatar
Hey Guys,
My right turn signal flashes at a very rapid rate compared to normal left. Anyone have any ideas what might be causing this?
Cheers
ibs
Old Jan 26, 2015 | 08:52 AM
Originally Posted by ibows1
Hey Guys,
Cheers
ibs
The most common cause is when one of the bulbs go out because the filament is broken or the bulb holder fails to make proper contact with the bulb.
Old Jan 26, 2015 | 06:43 PM
ibows1's Avatar
Thats exactly right I fixed it last night...THANKS!!
Old Oct 29, 2018 | 12:38 AM
Irekunso's Avatar
A little advise. The other day my son's turn signals both front and back just suddenly quit. After he parked it he noticed the back up camera wasn't working on the receiver but the radio still was. All the other external lights work properly. Checked every fuse. All good. No error codes read. However the faulty external light icon on the dash did come on. Is it a possibility that when the backup camera was installed a few weeks ago some how it could have caused it like a bad grounding or whatever since both did it at the same time?
Old Dec 30, 2022 | 12:01 PM
peter segola's Avatar
Originally Posted by oledoc2u
Talk to Rudy....he seems to have these cars memorized...lol
Check interior fuse box fuses / [ FUSE NO 12] THEY BECOME LOOSE OR WITH CARBON LIKE / CLEAN THE FUSES
OR CHANGE THEM WITH NEW 0NES .MAKE SURE THEY HOLD
Old Dec 30, 2022 | 12:33 PM
4 and 7 year old post.
Old Dec 31, 2022 | 09:08 AM
Jack G's Avatar
Can't some of these older posts be archived into the search function? If you don't check the post date you could be trying to help someone who no longer owns a xfire. This particular post initiated 12 years ago.
Old Dec 31, 2022 | 10:45 AM
1) You'd never find them, the search function here is worthless. The only search that works (for me anyway) is to go to Google and input: "Chrysler Crossfire _____ _____ ____ ". THe first few responses will be on this forum.
2) There are legitimate reasons to tag onto an old thread. The Sticky Key thread is a very good example of this.
Why can't people just look at the date of the post? That is why the date is displayed.
Old Dec 31, 2022 | 11:19 AM
Jack G's Avatar
People don't read, they react instantaneously and absorb a few bits of info. If the date was animated or flashing RGB they would react accordingly.
Old Dec 31, 2022 | 11:46 AM
They also don't read any of the responses and post something that has been posted again many times before.
Old Dec 31, 2022 | 12:23 PM
Most dont' even retain what little they 'absorb'.
Romad
Feb 11, 2021 10:18 PM
D&D
Jun 27, 2007 09:34 PM
D&D
Jun 27, 2007 09:27 PM
Robinhood
Jun 30, 2005 07:04 AM
MRODFIRE
Jun 19, 2004 08:15 AM
