Things I learned
Originally Posted by rcompart
It can't possibly be a drip pan as it would go back to the transmission as well. Darned transmission connector seals or not so seals anymore. Drip, Drip, Drip...
Code:
True... a Blue SRT6 is faster than a black Prius. ... just don't go up against a black SRT6, it will only make you want to paint your car. ;)
You'll want to paint it YELLOW!!! - LOL!
Sorry I just couldn't resist; I'll wait for both of you
Stay Safe...
Paul (MisterTaz)
Owner of the world’s 1st AMG 5.5 V8 Kompressor Powered Crossfire!
I will put the Aero up against any black SRT6...
... if I dont win, it will be fun
Paul, you're just showing off now....
... I LOVE the work you guys did on that engine... I do believe that there is a BLUE V8 running around also...just not SC....yet!
You have a beautiful car my friend...
Originally Posted by shapeshifter309
Where? You mean the skid plate? If so, I don't have this.
They didn't put a lot of stuff on the base models.
Originally Posted by JHM2K
Some say it does, some say it doesn't.
All I know is this: Steve (32krazy) ran his up over 100 without the drip pan. Felt a noticeable increase in turbulence and cowl shake. He reinstalled the pan, and no more turbulence... smooth on past 160.
I always run mine installed, and when I'm on Mexican roads doing over 140, it's smooth as a baby's butt.
So, I leave it in place...
I have been over 140 with Doc in his SRT roadster with the shields gone, it was rock solid as well.
You obviously did not buy the car new, all models of XF have the shield, my base certainly did, until I took it off.
There may be a minuscule difference, but not anything that I have noticed. I have been to the track a few times since I removed mine to include winning the Import Showdown where I raced against Steve in his SLK with his splash guard attached. Steve and I have pretty well matched up mods, and we are very close on 1/4 times as well. The run that I beat him was only by 13/100's IIRC, and that was basically the difference in our reaction times. It was my home track so I had the advantage of being very comfortable with the tree. Plus it was Steve's first time using his new DR's. I have been north of 150 as well with no discernible difference. Point is.... I doubt that there is any measurable gains by leaving the shield on. JMHO
No, no, no. I have the splash shield. I don't have the tabs or whatever they called them that hold it in place while you put it back on. And the heat shield on the underside of the hood just didn't come with my car I guess. I did buy my car in Florida, if that makes any difference. But yes, I did buy mine brand new. Only had 9 miles on the odometer when I got her. Got the lifetime powertrain warranty too.
Yes, you are correct, as Bob beat me to it above, the base did not come with the under hood heat shield ever, and as you well know, some other things are different / absent all together from the base LOL
OK shape, I guess I misread, my apologies.
Not to mention a few other electronic amenities that could eventually break down. Although, I wish the base came with fog lights.
Like those problematic seat heaters?
My favorite part about the car was the fact that you could change things and did not have to worry about lights going on on the dash. Full LED conversion with no bulb out indicator, full custom aftermarket wheels with no TPMS sensors and no light on the dash blinking at me
I just wish they didn't give us that troublesome ESP/TCS system. THAT would've been great.
I know about the TPMS and I'm very glad I don't have that either, but the base's bulb-out indicator doesn't do anything? I guess that would explain why I didn't know a taillight was out until a guy at the track told me when I was lining up to make my run.
Originally Posted by dinasrt
When my TPMS light went on to alert me that I had a slow leak going on, I was thankful to have this awesome lifesaving device. Fixed the leak($15.) filled it up, light goes out; peace of mind.....$priceless.
Again, some people see it as a convenience, I just see it as another electrical system that could give me trouble.
.....I check my tire pressure every time I go out to my car and bought a small air compressor that plugs directly into the lighter........
Good for some, needless for others. I've heard of a lot of problems with the TPMS giving false readings or going haywire. Either way, I check my tire pressure every time I go out to my car and bought a small air compressor that plugs directly into the lighter. I also have a rim that is bent that sometimes likes to leak 15 pounds of pressure out overnight (not all the time, just when it feels like it), and I'm sure the TPMS would love to alert me of this matter. Since I check my own air meticulously, I don't need it. Just another system that something could go wrong with. If I hit something and my tire's going flat, I'll feel it. I'm usually the guy that can hear or feel something way before any mechanic could even tell something was going wrong.
Originally Posted by MikeR
Why did you buy a compressor? Didnt your car come with a little air compressor stored in the back with the jack and a can of fixit gunk????
Don't be confused that I don't check my pressures regularly; and I've had no problems with it. The TPMS is there for a good reason; like I said, it has the potential to save a life. It lets us know before rather than too late. When on the road, it's a great safety feature. Trying to put a device like this down seems childish. A lot of us here have a lot more experience at "feeling" our cars than you. I think you just wish you had the system is all.
lol Just messin' w/ you.
It all comes down to personal preference really. If I could, I would have gotten one of the new Noble M600's. Doesn't even come with ABS.
the factory compressor is designed to refill the tires without the fix-a-flat connected... the fix-a-flat junk is designed with an input for you to hook the compressor and a little output hose the connects to your wheel.... compressed air pushes junk from can into your tire....
So you have a nice backup.....
Pretty much. It even has a nice empty slot for it in under the mat in the trunk.
