Things I learned
TO be clear, in the three Roadsters I've owned:
TOP PUMP - in wheel well on driver's side.
LOCK PUMP - in wheel well on passenger side.
All cavities under mat in trunk on all cars had things like Jack, Tire Seal in them. The cavities on the right were always empty.
And I do think the wheel well is a safer place for it, Dave.
and if you want to check if the oil level is OK while sitting at the drivers seat without having to open the hood and pulling the oil level rod:
- Turn the key to the ON/RUN position.
- After approximately 10 seconds, a clock and oil can icon will appear on the odometer.
- Press the left-hand **** twice to display the oil level. If all goes well, it should read "o.k."
- (i think this should be at the forum for all crossfires, not just the coupe)
I've owned mine since Jan 2010, and the other nite when I had the lights on, I opened the ashtray and noticed it was lighted. Never use the ash tray, except to store the cigar liter in it while I have the Garmin plugged in.
Also .... noticed a small black cushion/Disc where the console lid rests against the wall behind the seats.
Learn something new all the time ......
Here's another one for ya 13.
Press and hold both buttons on the key remote until the light (red lens at top of key fob) blinks twice. Now when you press the open button both doors and trunk will open with one push instead of two!
Repeat procedure to go back to two presses to open passenger door and trunk (why??)
juan vega
Aug 11, 2007 02:13 PM
jmackinjersey
May 25, 2004 12:49 AM
