Well... finally got my rotors in.
Ordered them from R1concepts. Took a little over a week to get here. Not sure what I think of them. I paid for the slotted premium replacements, apparently these are coated to prevent corrosion.
Here's some pictures of them: Rotors pictures by shapeshifter309 - Photobucket
As you can see, the coating on the rear rotors is rubbed or scratched off in some places. All of them are dirty in some way and greasy. Not sure what I think about this.
Also, does anyone know how much the original rotors weigh? These were 53lbs total.
on
Re: Well... finally got my rotors in.
They look pretty good.... I am sure they are coated to protect the untreated surface from rusting till they get to the customer... a good brake cleaner should take care of that... the black coating having chips/wear spots on brand new rotors would tick me off a little.... they should be packed so that dosent happen....
Once you de-grease them they should work wonderfully....
They'll for sure be cleaned up before being put on. I can't imagine the pads working well with all the grease covering it, or for it being good for braking at all.
Still curious if anyone knows how much the stock rotors weigh.
on
Originally Posted by shapeshifter309
The rotors were actually starting to come through 2 boxes, but I think they probably couldn't pack it much better than they did. Bubble wrap might of helped a little.
Stock rotor = alot lbs. I don't remember exactly but my rears where rather heavy for my SRT
On a slightly related topic, I have one more package coming in from NeedsWings that contains a front rim and SS brake lines. I'll probably be happy with my purchase when it gets here, I'm just wondering if Fedex is planning on taking it on any more side trips.
Here's the map of where they've taken it so far: US map - Google Maps
Mind you it's going to Peoria, IL- 170 miles south of Chicago down I-55/I-74. For some reason, Fedex decided it was a good idea to take it 250 miles THE OTHER WAY, almost to Pennsylvania, then 415 miles back the other direction to Chicago. I'm sure there's some "special" reason why, but how (logistically speaking) does this make any sense? Maybe they forgot to take it off the truck and it ended up going the wrong way? Either way, I find it quite humorous, although I'll be certain to never ship anything Fedex. Not blaming Rob (Needswings) at all for this, just Fedex. Christ, they're dumb.
They look just like they should. They come coated so they don't rust while waiting to be bought. Did they come with instructions? Mine did and they say to wash them with soap and water before installing them on the car. I have the stock weights somewhere but I imagine the R1's weigh the same as the stock rotors.
Les
Les
on
They look pretty good.... I am sure they are coated to protect the untreated surface from rusting till they get to the customer... a good brake cleaner should take care of that... the black coating having chips/wear spots on brand fine-just more work.
.new rotors would tick me off a little.... they should be packed so that dosent happen....
BTW- if you really want to know, I can weigh my OEM N/A rotors in the morning. I have them at my lab. Do you really want me to?
Les
Les
I feel the same. Mine arrived exactly the same way. They don't pack them expecting them to be mounted on a show car. Unfortunately. I re-sprayed the hubs on mine silver to match the hubs, spacers and wheel. I would use a good de-greaser and skip the dish soap. But, that's just me..if you don't, the coating (grease) will ruin the pads. Fast.
Like I mentioned (obviously you didn't see it because I just posted it though), I'm gonna have a shop do the entire job just in case I would break something. I don't really have the equipment to do it either, so I doubt it would be a good idea. They probably already know to, but I'll tell whoever I take it to to wash the rotors with degreaser before mounting them.
And if you REALLY want to weigh them, feel free. It won't kill me if you don't, but myself along with anyone else that would want to know would sure appreciate it if you did. No pressure though. Like I said, I won't die if I don't know. Just curious.
Originally Posted by Never_satisfied
Mine came the same way. After breaking them in along with my pads they have performed very well.
I went with Akebono Euro ceramics from tirerack. Hopefully they'll be ok for a few autocrosses a year.
Originally Posted by Joliet John
Everything from FedEx goes in to once facility, sorted, then out from there. Logistically, it's the best way to do it. Otherwise, you'd have to send multiple planes to one location.
USPS and UPS have always taken the shortest route (sort facilities taken into consideration). If I get a package from Indiana, it might go through Chicago first even though it could hypothetically just go straight across the state line to the middle of Illinois, but there's a huge sort facility in Chicago where most of their packages would get sent out to their different destination cities, and in addition Chicago isn't really the opposite way from the destination, it's just a slight detour. This package, on the other hand, went the complete opposite way on the same highway, then came back down that same highway to Chicago.
Again, they may have some magical explanation, but I find it comical that it would go 250 miles the other way, passing through a major city, to come back down the same road. But hey, I can't complain cause it's still getting here on time.
I am running the same rotors on my Daytona Ram and on my Miata. Other than being noisy when applying brakes they seam to be alright. one thing I have learned, I will not be using any more greenstuff brake pads lots of dust and not a real firm feel when hard on the brakes.
What pads did you buy?
TnaskiI am running the same rotors on my Daytona Ram and on my Miata. Other than being noisy when applying brakes they seam to be alright. one thing I have learned, I will not be using any more green-stuff brake pads lots of dust and not a real firm feel when hard on the brakes.
Once the rotor and pads where broke in the rotors stopped rusting up and even stopped better. I found and followed the break in guidelines I found on the forum here and things have been working great. Very pleased with this setup so far!!!
Bring it over to my shop and I will help you get them on there.
on
Are these the ones you ordered? Im wanting to upgrade too and thought these from R1concepts where the best $
Brand : R1 Concepts (Eline Slotted) Front Brake Rotors › Description : Slotted Brake Rotors › Sale Price : $ 114.20 (pair) › Retail Price : $ 182.72 › Sku : ES.35058 Qty: 1 2 3 4 5
Rear Brake Rotors › Description : Slotted Brake Rotors › Sale Price : $ 77.60 (pair) › Retail Price : $ 124.16 › Sku : ES.35012
R1 Concepts PREMIUM SERIES BRAKE DISC WITH BLACK E-COATED HUB
2007 CHRYSLER CROSSFIRE Front Brake Rotors - Slotted ps.35058
2007 CHRYSLER CROSSFIRE Rear Brake Rotors - Slotted ps.35012
And The Pads I used:
Satisfied's GranSport GS6-Pads
Satisfied GranSport 6 Pads
on
