Rotors - Brakes
Old Oct 21, 2010 | 09:14 PM
Chris L.'s Avatar
Default Rotors - Brakes
So has anyone ever actually been told that their rotors could not legally be turned (due to being worn too thin)? If so, how many miles were on the vehicle? Was it mostly city driving? If the brake wear light has ever gone off in your car - what was the odometer reading when it lit up?
Fred crossed the 50,000 mile mark last week....80% highway...purchased 12/5/07 new......
Old Oct 21, 2010 | 09:28 PM
MikeR's Avatar
Default Re: Rotors - Brakes
not on the Crossfire... but yes... there is a spec for minimum thickness to allow turning... different for each type/manufacturer of rotor... turned too thin and they will heat up faster and warp worse...
When I had the C32 rotors turned before I installed them they checked them with a caliper before they would agree to turn them....
Old Oct 21, 2010 | 09:33 PM
JHM2K's Avatar
Steve can chime in with the exact numbers, as he just helped Jason (goodgenes79) with his brakes this weekend.
To answer your question, yes there is a minimum thickness but it takes a lot of abuse to get there
Old Oct 22, 2010 | 12:11 AM
Minimum thickness is;
Front - .890"
Rear - .300"
Material has to be machined off approximately evenly from both faces.
Old Oct 22, 2010 | 02:38 PM
AlG's Avatar
AlG
Just had the brakes and rotors changed on mine. 51,700 miles on them. Only needed the fronts and yes the service guy told me there's some kind of lip on the rotor and it couldn't be cut either. They didn't have the parts but got them the next day but I didn't care because my dealer has loaner cars. $789.00 to do the job. They screwed me on the parts but the labor was only $160.
Old Oct 22, 2010 | 06:20 PM
Chris L.'s Avatar
Well, to my recollection the pads don't contact the rotors all the way to the edge....so as the rotor wears down you can feel a "lip".....
I've never heard the "lip" as a reason they can't be turned... maybe that's not BS ??? Anyone understand why that might be true?
At $789 for fronts only....I'd be inclined to say , "Just put on new pads & skip the turning (if it can't be done) or new rotor". At least till someone told me the rotors are so thin that they might fail...
Last week I had new front rotors & pads put on a Chevy HHR....total cost with tax was $261....& ya know the XF front rotors don't look like they should cost 3X as much???
Old Oct 25, 2010 | 01:48 PM
AlG's Avatar
AlG
You're right and I told my dealer I could get aftermarket for less than that and he said that I was paying M-B prices for M-B parts and he's right on that. They honor their warranty work real well and I've never had a problem there so I figured it was worth a little extra. Hell, the guy at the local garage doesn't charge any less than the dealer and he doesn't warranty his work at all.
Valk
Jun 22, 2025 09:15 PM
oldbiff
Mar 19, 2023 11:37 AM
RamblinShamblin
Aug 12, 2017 10:55 PM
8ighth Wonder
Dec 15, 2015 01:42 PM
leaddog2015
Sep 26, 2015 08:23 PM
