I'm going to get my ECU tuned by Eurocharged but how do I take it out?
Old 02-14-2011, 04:56 AM
bionicdriver's Avatar
Default I'm going to get my ECU tuned by Eurocharged but how do I take it out?
Anyone know how to remove the ECU from a 2004 Chrysler Crossfire. It dosent seem as easy as it might look
Old 02-14-2011, 08:46 AM
Bill F's Avatar
Default Re: Im going to get my ECU tuned by Eurocharged but how do i take it out
Talk to EUROCHARGED about getting it done by remote. You can also go here if you still want to send it in. ECU Removal Instructions
Old 02-14-2011, 09:04 AM
FUBU's Avatar
Eurocharged have a DIY plan on their site.
Old 02-14-2011, 09:05 AM
FUBU's Avatar
What do they actually do with the ECU? What do they alter? will it harm the engine as the take of the limiter? raise the revs?
Old 02-14-2011, 12:40 PM
Fubu, I know this may be strange to you, but there is a hell of a feature here called the SEARCH.
Tunes are one of the most widely discussed thing in the performance section. Do a search, grab a beer, and enjoy your reading....
Old 02-14-2011, 01:47 PM
FUBU's Avatar
Hahaha being valentines day and all I thought I would get lucky
Old 02-14-2011, 01:50 PM
oright i went to the website and its easy. I want to go to chicago and get it custom tuned which i probaly will alot of plans for this crossfire including larger injectors and a cold air intake . Does anyone know what size the oem fuel injectors are in a n/a crossfire?
Old 02-14-2011, 02:49 PM
You still might, but not on this forum
From what I understand, the OEM injectors are powerful enough to work even if you add quite a bit of power (over 100HP to the wheels)
Unless you are doing something wild with forced induction and adding a LOT of air, you willl not need larger injectors and they could actually harm performance....
Old 02-28-2011, 04:41 AM
nox1s's Avatar
Hrm, I wonder why TvT once offered the larger injectors as a performance mod with their TvT265+ (or whatever the hell it was) kit?? Just something additional to make it seem like you're getting osmething better?
Old 02-28-2011, 08:29 PM
I believe there was a throttle body, injectors, cold air intake and a tune needed to bring it all together as I remember their offer. Just upgrading injectors wouldn't get you anywhere.
Old 03-02-2011, 05:16 PM
Default Re: I'm going to get my ECU tuned by Eurocharged but how do I take it out?
I believe the general consensus on injectors a few years ago when this was discussed in depth was that the N/A's injectors are running upwards of 80-90% duty cycle stock (smart engineering - only buy what you need to make your design work! ... but bad for us), meaning that intake mods like a CAI and throttle body would push the car up against the limitations of the injectors.
That thinking is only based on others' specifications, though - while I can do the calculations, I'm trusting forum members for the specs. I don't have upgraded injectors in my car and have never dyno'd.
https://www.crossfireforum.org/forum...4-750-rpm.html has more information.
Unfortunately it seems that nobody's done a complete step-by-step mod-and-dyno for this car (probably for cost reasons), so it's hard to say what parts gain what in what combinations.
Old 03-02-2011, 11:23 PM
ZAHANMA's Avatar
I don't think anyone has done a step-by-step dyno on a N/A. Eurocharged did a step-by-step dyno on a SRT a while ago.
Old 03-03-2011, 03:05 PM
I believe the general consensus on injectors a few years ago when this was discussed in depth was that the N/A's injectors are running upwards of 80-90% duty cycle stock.
I was under the impression it was the other way around.
I know people who were already heavily modded and added injectors and saw power loss, not gains. I thought the NA injectors were good for something like 350-400 HP, so unless you are going serious FI or N20, I don't think they are necessary.
Someone please correct me if I am wrong.
Old 03-03-2011, 04:10 PM
I thought TVT said 300 hp at one time.
Old 03-03-2011, 04:51 PM
Thirteendog's Avatar
Have you noticed, TVT isn't around anymore
Old 03-03-2011, 10:40 PM
I'm always willing to learn even at this stage in life.
So, why does the SRT have larger injectors?
Am I missing something?
Have you noticed, TVT isn't around anymore.
It does not nullify what they said. I may have attributed it to the wrong person, I'll search for it.
Found it,https://www.crossfireforum.org/forum...tml#post353907
The old memory still works.
Old 03-04-2011, 08:43 AM
Notice above where I said serious forced induction would be a reason, well most SRT guys pushing 15-18+ lbs of boost IS serious FI, hence the need for the larger injectors.
I stand by my statement, until someone shows me proof, not ramblings from a banned member.
Dave I thought you better than to quote someone who is banned, and for bad business practices no less.
Any dyno's to go with those quotes????
Old 03-04-2011, 09:54 AM
Why does the SRT have larger injectors then? The stock SRT fits into your range.
We were talking about na injectors remember.
I would quote Charlie Sheen if he said something that seemingly made sense to me.
As I said before I'm willing to learn - or at least try.
Old 03-04-2011, 11:54 AM
Bladecutter's Avatar
SRT6 needs larger injectors than the N/A Crossfire because there is a much larger volume of oxygen being squeezed into the combustion chamber by the supercharger.
More Oxygen in the combustion chamber needs more fuel to get the proper fuel to air ratios. Hence, the bigger injectors.
The N/A Crossfire needs bigger injectors when you are flowing more air at the top of the rpm range, as the stock ones are pretty much limited with their current limits.
And just because someone is no longer liked on a forum doesn't mean that you discount any information that they had provided in the past.
I am sure TVT included step by step instructions on how to install all these different parts on the car, so you can't say that the information he provided isn't useful. Why he was banned has nothing at all to do with the quality of the information he has provided to the forum.
Until someone can debunk his information, it stays, and still provides benefit to those willing to use it.
BC.
04-28-2016 02:04 AM
steps
10-13-2015 06:18 PM
10-01-2015 01:42 AM
brandoni
09-30-2015 07:48 PM
09-28-2015 07:40 PM
Quick Reply: I'm going to get my ECU tuned by Eurocharged but how do I take it out?
