major creaking/noises in the drivers door panel...ne1 else?
Old May 20, 2004 | 09:09 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default major creaking/noises in the drivers door panel...ne1 else?
if my knee rest against the panel when driving the creaking worsens. passenger panel is fine. is it just my crossfire?
Old May 21, 2004 | 04:00 AM
gregthegr8's Avatar
Default
ya, i have that, although mine comes and goes. if i rest my knee against the silver handle there, as i tend to do in this car, the door tends to creak. also when i have my arm on the arm rest and lean too much into the door. it's annoying and i may ask to have it looked at when i take it in for the first time.
Old May 21, 2004 | 04:42 AM
garmin's Avatar
Default
I think it has something to do with the seat--- if your seat is all the way back you'll get some noise, move it just a little away from the panel and it'll be fine... mine did the same thing, then i moved the seat position a little and it's squeak free.
Old Jun 29, 2009 | 09:35 PM
andrew's Avatar
Default Re: major creaking/noises in the drivers door panel...ne1 else?
~ update for others in need...
the dealer would replace the panels under warranty to eliminate the creaks but the kept coming back every 12k or so.
but if one is out of warranty (most are) - i removed the panel and add some padded foam tape to the plastic contact points to aid with the noise.
Single Sided Low Density PVC Foam Tape on Tapes & Technical Solutions LLC
cheers,
andrew
Old Jun 29, 2009 | 10:15 PM
maxcichon's Avatar
Thanks Andrew. Little things (info) for the forum really keeps us happy!
88stevie
19
Jan 21, 2026 01:46 PM
xfClifford
Sep 6, 2015 08:20 PM
wannaGOFAST
South Forum
Aug 14, 2015 01:20 AM
66L72M21
Jul 15, 2015 04:23 PM
2005 Ragtop
Jul 9, 2015 03:16 PM
