seat belt chime disabled / heated seat doesn't work
Old Oct 1, 2011 | 06:06 AM
ant.lan's Avatar
Angry seat belt chime disabled / heated seat doesn't work
hi everibody..
i bought an used crossfire
this car has seat belt chime already disabled (probably by the old owner). how i can enable again this function???
another thing: my heated seat (driver and passenger side) doesn't work, works only the back not the seat...why?
the disabled seat belt indicator/chime and the heated seat are linked ???
help
thank you
Old Oct 1, 2011 | 06:10 AM
FUBU's Avatar
Default Re: seat belt chime disabled / heated seat doesn't work
Originally Posted by ant.lan
hi everibody..
help
thank you
It is broken. Buy a repair kit and get to work need soldering and a gluegun. I have done it. Seats needed to be taken out. Takes you about 3 hrs a seat the first time.
Old Oct 2, 2011 | 02:41 AM
DavidOv54367's Avatar
Do you know if the seats would be covered under the 3/30k warranty?
Old Oct 2, 2011 | 03:09 AM
FUBU's Avatar
I do not but go there as if. And state that others have.
Old Oct 2, 2011 | 07:17 AM
andrew's Avatar
-C-I-C-C-I Associate Member
~ what year and color combo is your crossfire? it may have been mine...
Old Oct 2, 2011 | 08:47 AM
killerkanadian's Avatar
Seat belt chime in my xf drives me crazy. Can't drive the car to the mailbox with out it screaming in my ear lol...
Where's the How To to disable it Or is it just a fuse to unplug?
Old Oct 2, 2011 | 06:11 PM
andrew's Avatar
~ see link: https://www.crossfireforum.org/forum...ing-chime.html
Old Oct 2, 2011 | 07:15 PM
Thanks much
Old Dec 11, 2011 | 10:55 PM
crossingmatt's Avatar
Do you have a link to a "how to" ? I have the exact same problem as the original poster
Old Dec 11, 2011 | 11:02 PM
https://www.crossfireforum.org/forum...structions.pdf
Anything else Sir?
Old Dec 11, 2011 | 11:10 PM
Mrmiata's Avatar
See post 2 above yours.. click on the red text.
Old Dec 11, 2011 | 11:47 PM
He's asking about the seat repair, not the chime.
Old Dec 11, 2011 | 11:57 PM
For disabling that damn alarm WITHOUT taking seat out or cutting any wires, just do THIS! (reprinted from a post in this great forum)
1) With the key in the ignition switch in any position except ON or START, buckle the driver's seat belt.
2)Turn the key to ON and wait for the chimes to stop.
3)Unbuckle, then buckle the driver's seat belt 3 times, ending with buckled.
4)Turn the key to any position except ON or START and wait for a sinlgle chime which indicates the reminder chime is off. (This may take up to ten seconds.) The initial chime will still sound when you start the car, but the repeating reminder chime will not.
An electrical system disconnect or repeating the above sequence will reinstate the chime. For the seat belt light which remain on, I recommend a strategically placed circle of tape.
This solution will stop that annoying chime and will not require any mod to any electrical wiring. Easily reversable and when you trade it in its safe for the next owner by resetting (disconnect battery negative cable or use the sequence again). My ending chime sequence was different but the result was the same. NO MORE CHIME when I move the car a few feet, thats great! Try it, it works!
Old Dec 12, 2011 | 12:00 AM
[quote=onehundred80]He's asking about the seat repair, not the chime.
Yeah I was. Screw the chime I just want my heated seat bottoms to work. Thanks for the link onehundred80 but I was hoping for a how to from someone who's done it with pics included. Instructions are nice (if they're well written) but a step by step with pics by someone who's done it and can explain it in an idiot proof way is priceless.
Kodebuster
Nov 5, 2020 04:06 PM
axnguyen
Jul 21, 2015 11:41 AM
Tp'sfury
Jul 17, 2015 01:15 PM
JEFASOLD
Jul 15, 2015 02:32 PM
Seawolf
Jul 12, 2015 06:20 PM
