Transmission fluid cap?
Old Nov 9, 2011 | 07:42 AM
hilarushi's Avatar
Default Transmission fluid cap?
I just got a crossfire and I want to check the transmission fluid level. I have had several MB and I know that there is no dipstick for them. On the MB and my previous SLK there is the tube that comes up and has the cap that you can take off to measure the fluid level. I even have an OEM dipstick. On my MB I have taken the cap and measured the fluid many times. The problem that I am having with the crossfire is that there is no tube that comes up. There is a round cap (not the one used on the tube that comes up) right on the transmission case. First question, is this how the crossfire is supposed to be? Do they not even have the tube that comes up from the trnny? If so, how can I take that cap off, without braking and having pieces fall in?
Old Nov 9, 2011 | 08:01 AM
LantanaTX's Avatar
Default Re: Transmission fluid cap?
There is a tube with a sealed cap on it. You have to break the red tab to remove it. The cap can be reused without the red locking tab. I believe it near the back of the engine on the passenger side.
Old Nov 9, 2011 | 08:35 AM
tighed1's Avatar
What he said. Assuming we are talking about a auto trans.
Old Nov 9, 2011 | 08:49 AM
hilarushi's Avatar
Thank you for your quick replies.
Yes, it is an auto.
The problem is that, this doesn't have the tube that comes up and has the cap you mention. I am aware of that at least on MB. The plug on this is right on the transmission case. Usually there is the tube, comes up and then its the cap you are talking about. The crossfire doesn't have that. Is that how it is supposed to be?
Old Nov 9, 2011 | 08:54 AM
IBLUBYU's Avatar
Yes, it is an auto.
Should be there, right behind the engine, on the passenger side. Someone should be able to post a picture.
Old Nov 9, 2011 | 09:02 AM
hilarushi's Avatar
I think I am not being very clear. I know where the tube is supposed to be, and where it connects on the transmission. I am also aware of the cap, how it looks and how to take it off. The problem is that the dipstick tube is not there. There is a cap right were the tube is supposed to be connected on the transmission case. I have serviced my previous SLK on the past. From what I am gathering the crossfire also is supposed to have the tube, for some reason my doesn't have?
And I am asking the question because under hard acceleration the car goes into limp mode and I wanted to check the level.
Old Nov 9, 2011 | 09:07 AM
YES, there is supposed to be a tube with a cap. Seems someone removed it. I would suggest searching around the part-out adds in the forum, or the internet for a salvage car that is being parted out.
Old Nov 9, 2011 | 09:19 AM
hilarushi's Avatar
That answers my question.
Thank you all.
syfi
Mar 28, 2026 04:14 PM
UNDER PSI
Nov 1, 2015 09:39 PM
jimf
Oct 10, 2015 10:22 AM
Oct 1, 2015 01:42 AM
rfourt
Sep 25, 2015 01:38 PM
