Electrical gremlins need help.
Old Jan 4, 2012 | 11:05 PM
Default Re: Electrical gremlins need help.
The run on I assume is a fault of the switch, the cut off not being activated. Study the ignition switch circuit.
The lights?????????
Do you still have the same problems you started with?
Old Jan 7, 2012 | 02:24 PM
cmac's Avatar
Well I sorted out my brake light problem. Bulbs were in the sockets at a 90° orientation to the supposed location. Keeping the bulb constantly in contact with the two contact points. I havebt encountered the run on again but I did have the battery and RCM out so maybe a connection was loose. As soon as I looked at the socket with a light i knew it was in wrong. I'll post back if the run on occurs again.
Mike OD
Sep 23, 2016 07:00 AM
Franc Rauscher
May 9, 2016 12:04 PM
nataliefs
Oct 5, 2015 01:03 PM
Charlesl
Sep 30, 2015 10:46 PM
livefreeordie
Sep 22, 2015 08:13 PM
