Hood lever won't pop the Hood! How do I pop the hood form the outside?
Old Mar 19, 2012 | 10:37 PM
Lee337's Avatar
Default Hood lever won't pop the Hood! How do I pop the hood form the outside?
I went to pull my hood release lever to check my fluids and the hood won't pop open.
I had my radiator replaced not too long ago and they might have messed up my hood cable...or I just need to lube the latch.
..either way,
How do I pop the hood latch open? Coat hanger? Large screwdriver? Where do I put it?
Old Mar 19, 2012 | 10:52 PM
Default Re: Hood lever won't pop the Hood! How do I pop the hood form the outside?
first have someone pull the lever all the way while you push the hood down and then lift,, if the hood latch is too low this should open it then raise the latch about 1/4" hope it works. jim
Old Mar 20, 2012 | 07:12 AM
..either way,
There is a post here somewhere that explains how to use a wrench to unscrew the bolts that hold the latch down to thread support. The wrench goes through the grill, it takes a while but can be done.
Old Mar 22, 2012 | 10:41 AM
Lee337's Avatar
Alright finally got the hood open! I saw the thread to unscrew the latch. I unscrewed the 2 screws of the latch using a 10mm wrench halfway, joggle the hood a little and hit the release lever on the hood.
The mechanism was getting stuck. Guess it's this pollen season that dried up the latch.
Just got to tighten my cable a little and put some WD40 to oil down my latch mechanism.
Thanks yall!
Old Mar 22, 2012 | 12:22 PM
maxcichon's Avatar
Thanks yall!
Lee (county?) 37:
Give me a PM! I've seen you driving around...
Old Mar 22, 2012 | 04:49 PM
chevyboyac's Avatar
NOOOOoooooo wd-40 on the latch or any latch ever it just gathers dust ....oh it will work for a few weeks until it gums up ...they make dry lube that doesnt collect dust and pollen use that
Charlesl
Sep 30, 2015 10:46 PM
Padgett
Southeast Forum
Sep 27, 2015 09:37 AM
eatmycrackers
Sep 23, 2015 09:08 AM
waldig
Sep 17, 2015 10:35 AM
