Door Lock Problem
Old 04-28-2012, 12:53 AM
Joliet John's Avatar
Default Door Lock Problem
Having a problem with my driver's side door lock not working - Can't move the lock button up or down. I took the latch out and found the problem is this little white piece which blocks the latch from moving. Why?
If I manually move that piece out of the way, it works fine. I'm tempted to take some snips and hack it off, but, obviously, it's there for a reason.
Any ideas how it's supposed to work? What's wrong?
Unlocked - that small white piece prevents the mechanism from moving into the locked position.
Locked - if I move that white piece out of the way, the lock works fine.
Old 04-28-2012, 03:28 AM
Default Re: Door Lock Problem
Well, I need the car in the morning, so I had to make a decision. After a long period of careful analysis and some discussion among myselves, I decided that little white thing to be an extraneous, unnecessary part and did some careful surgery to remove it. Everything works fine now.
As for getting the inner door handle to work... Wow! What a PITA! It was like I needed to adjust the cable a bit, but it's not adjustable.
pioneer4x4
03-25-2019 10:35 AM
Hoppy
12-07-2018 07:36 AM
gtjl
17
07-22-2015 06:28 PM
55chevy
07-20-2015 03:08 PM
66L72M21
07-15-2015 04:23 PM
Quick Reply: Door Lock Problem
