Key fob dead?
Old Jan 18, 2018 | 09:01 AM
Default Re: Key fob dead?
Originally Posted by hokkabaz
After I changed the batteries on the fob, i unplugged the negative end of the cars battery and waited for couple of minutes. Connected back and boom, it worked. I dont know if changing the fob batteries were really dead or there was something wrong with cars system and it reseted when i disconnected the negative end but i am glad it worked
Is it possible that the battery in the car was dead? If the car battery is dead then the signal from the fob may not operate the CLP/SSM in the trunk, after all the system the fob signal operates is run by the battery.
If it happens again, get a new battery put in the car.
Old Jan 18, 2018 | 02:59 PM
hokkabaz's Avatar
I got a new battery last year and it has been working good but I realized that battery seemed little weak when I was starting the car day before. It has been extremely cold in the past couple of days, i am in San antonio/texas and I have never seen it this cold before. It goes down to lower 20s right before sunrise so maybe that is the reason. Thank you!
Old Jan 18, 2018 | 03:53 PM
Bad battery, bad contact at battery terminals, bad battery cables, take your pick of these if it is battery related.
Old Jan 19, 2018 | 02:54 PM
Bad FOB Batteries Will Have No Effect On Car Starting Or Not Starting!!
Old Jan 23, 2018 | 06:00 PM
JasperHalland's Avatar
It sounds like the key signal is not connecting with the car to disable the antitheft features. DO both of your keys have this problem or just one? That would be a good indication of whether it the key or the vehicle.
Old Mar 3, 2018 | 05:47 AM
MAGNATUDE's Avatar
I experienced the same symptoms not long ago. Both of my key fobs exhibited no remote functions and no key on/engine start.
It turned out to be a loose (+) cable connection at the car's battery. Easy fix.
fastfred
Nov 5, 2018 09:47 AM
o55ie18
Oct 5, 2015 05:50 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Padgett
Southeast Forum
Sep 27, 2015 09:37 AM
xjken
Sep 13, 2015 10:18 PM
