2006 crossfire oil filter cap leaking
Old Jun 15, 2013 | 09:46 AM
wvamathteacher's Avatar
Default 2006 crossfire oil filter cap leaking
I just traded up a 2006 crossfire with 82000 miles on it and the oil canister cap is seeping oil thought putting new filter and o rings would fix problem but didn't do I need to buy new canister cap?
Old Jun 15, 2013 | 09:57 AM
Toolman's Avatar
Default Re: 2006 crossfire oil filter cap leaking
There is also an o-ring at the top of the threads on the oil filter housing/cartridge cap. If that o-ring is damaged you would get leakage from it. I have not seen just that o-ring for sale. You may have to purchase the entire filter cartridge. Someone else may be able to chime in on how to get just the o-ring.
Old Jun 15, 2013 | 10:59 AM
maxcichon's Avatar
It's a standard (Metric) O-ring. You should be able to find one at any industrial supply.
I would suggest Viton for synthetic oil service.
The last time I bought a K&N filter, it came with that o-ring.
K&N PS-7004
Mann:
Mann-Filter HU 718/5 X Metal-Free Oil Filter : Amazon.com : Automotive Mann-Filter HU 718/5 X Metal-Free Oil Filter : Amazon.com : Automotive
Mobil 1:
Mobil 1 M1C-253 Extended Performance Oil Filter, Pack of 2 : Amazon.com : Automotive Mobil 1 M1C-253 Extended Performance Oil Filter, Pack of 2 : Amazon.com : Automotive
All of them did-I checked. I have them all on my shelf!
Old Jun 15, 2013 | 03:25 PM
I changed cartridge filter and replaced 3 orings including the one on the cap still leaking might buy new cap from dealer
Old Jun 15, 2013 | 03:27 PM
I bought fram tough guard filter7 quarts of mobile 1 0/40 synthetic oil and a quart of lucas synthetic additive car runs great just got to figure out the oil seepage at the cap thanks for the help
Old Jun 15, 2013 | 04:55 PM
robby363's Avatar
You said you replaced 3 o-rings, there are 4 o-rings on it. If you tighten it to much it can cause it to leak. Are you tightening it by hand or are you using a wrench on it? The first couple of times I changed the oil I used a filter wrench to tighten it and it would leak. I've never had it leak again after I started tightening it by hand.
Old Jun 15, 2013 | 06:47 PM
+fireamx's Avatar
Are you absolutely sure that the largest O-ring is in its proper position?
Old Jun 15, 2013 | 06:50 PM
Originally Posted by +fireamx
are you absolutely sure that the largest o-ring is in its proper position?
+1......
Old Jun 16, 2013 | 02:38 PM
harbor's Avatar
Per the last three posts, make sure the large O-ring is in the second groove from the top; not all the way to the top. Unless the filter housing has a hairline crack, it shouldn't need to be replaced. I'm betting its an O-ring or over tightening issue.
Here's a pic from a prior post that shows the O-ring placement.
https://www.crossfireforum.org/galle...il_gaskets.jpg
Old Jun 16, 2013 | 03:02 PM
Thomas B. Whyle's Avatar
I had this happen once: It was because I didn't push the filter on the spindle with enough force to snap it into place. When I pulled the filter housing to investigate, the filter fell right off the spindle. I have discovered that some filters have a tighter collar and require more force to seat. On the filter housing there is a reference mark which will be at "nine o'clock" (viewed from the front of the car) when the housing is sufficiently snug. TBW
Old Jun 16, 2013 | 03:05 PM
velociabstract's Avatar
The only time mine leaked was installer error. The top 0 ring goes in the second groove from the top.
Les
Old Jun 16, 2013 | 06:30 PM
+1 on placing the cap 'O' ring in the SECOND groove, I would also suggest you torque the cap to the proper tightness!
Old Jun 16, 2013 | 08:32 PM
harbor's Avatar
Like I said, I'm betting its an O-ring, over tightening or filter/spindle issue .
Mathteach - let us know the final resolution since, hopefully, you have all summer off to resolve this leak.
Old Jun 16, 2013 | 08:43 PM
Let's have a picture not a postage stamp. LOL
The four O-rings are shown in position.
Over tightening within reason will not cause the leakage. You will break the filter housing first and cause leakage, the O-rings are in grooves that prevent leakage from over tightening.
roland1226
Feb 26, 2019 10:19 PM
racingagent
Jun 8, 2015 07:29 PM
MJPowers
Jun 8, 2015 02:34 AM
gobraves423
Jun 6, 2015 07:03 PM
Ephr8a
Jun 4, 2015 12:42 PM
