crankshaft position sensor connector
Old Oct 4, 2013 | 02:41 PM
pgwwheeler's Avatar
Default crankshaft position sensor connector
Does anyone know where I can get a Crankshaft position sensor connector. Mine is flaky. I have a 2004 Crossfire. Phil
Old Oct 4, 2013 | 04:25 PM
sk8erjosh09's Avatar
Default Re: crankshaft position sensor connector
What makes you think the connector is flaky? Just out of curiousity.
Old Oct 4, 2013 | 04:35 PM
pgwwheeler's Avatar
If you touch the connector while car is running it dies. I am positive the connector is flaky. I have a degree in physics and have worked on cars and bikes all my life was a cyclotron tech at the cyclotron in Bloomington In I am 61 yrs old.
Old Oct 4, 2013 | 04:38 PM
Just wanted to know what method of checking your conclusion came from.
I have a cut connector I could mail you? Or you could ask MrMopar?
Old Oct 4, 2013 | 06:00 PM
velociabstract's Avatar
My CPS was giving a random hard start and equally random code. In went a Borg Warner CPS and every time I hit 4000 rpms the car quit. Reinstalled the original Bosch after cleaning, a little dialectic grease, plugged and unplugged it a few times to make sure it was correctly seated and life is good. Personally, I think a lot of the CPS problems are connector related. I doubt the connectors are bad, just loose or dirty.
Les
Old Oct 4, 2013 | 06:26 PM
pgwwheeler's Avatar
That would be great my email is pgwwheeler@hotmail.com we could discuss that more there. Phil
Old Oct 8, 2013 | 02:55 AM
hotwheels's Avatar
Will the car try to crank over? Just wondering becuz mine quit for no reason at stoplite today...after being towed to garage the mechanic was able to just start it up, like nothing happened....do crossies like to play tricks? Does this sound like a sensor? Mechanic mentioned that. I know its just that gremlin that lives under the hood....speaks german too the little sob.
Old Oct 8, 2013 | 07:09 AM
Mrmiata's Avatar
"Normally" you will get a check engine light with the CPS.. sounds like you need to click the Video RCM link in my signature.
syfi
Mar 28, 2026 04:14 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
RED DOG
Oct 5, 2015 07:59 PM
ala_xfire
Sep 28, 2015 05:51 PM
bobbie
Sep 12, 2015 12:49 PM
