Need Help!!! Key wont turn
Old Nov 16, 2013 | 12:52 PM
BobbyCaz's Avatar
Default Need Help!!! Key wont turn
Yes i have read the articles on how to fix the sticky key. Wish those pictures were still available.....lol.
The key wont turn to remove the tumbler from the housing. tried over a thousand times. The steering Wheel is locked. I've tried to push in the pin, or at least what i think is the pin, to turn and remove housing. Won't budge. From what I've read. I'm screwed. I now need to drill out the pin, Yes?
The pin i am talking about, is the pin, just to the left of the collar that holds the housing in? Yes?
This silver pin. That i am assuming needs to be drilled out in order to completely remove the housing. Yes? And then i can replace the tumbler?
Does that pin need to go back in? or is the collart what holds it in place?
Just not sure if the pin i am describing is the rite pin. And does it need to go back in. Or is it garbage?
Old Nov 16, 2013 | 01:02 PM
BobbyCaz's Avatar
Default Re: Need Help!!! Key wont turn
I left my shop to come home and grab a drill and bits. I just want to make sure that i am drilling out the rite bit,,,,,
heading back now. Will check to see if anyone has answered, so i don't screw this up.
Thanks for your help guys....
Old Nov 16, 2013 | 01:06 PM
It sounds like you are on the right path, but pictures are right here:
https://www.crossfireforum.org/forum...key-fix_v2.pdf
Old Nov 16, 2013 | 01:18 PM
BobbyCaz's Avatar
Pizza Guy. Cant thank you enough for those.
One more question......That pin that needs to be drilled out. Does it need to be replaced. Or is that the pin that is the issue, that some have removed completely.
88stevie
19
Jan 21, 2026 01:46 PM
SparkieSRT6
Jan 11, 2016 10:49 PM
unarel32
35
Oct 6, 2015 05:53 AM
spoiler
Sep 2, 2015 08:56 PM
TOPLA
Jul 14, 2015 07:46 AM
