Timing Belt
Old Jan 21, 2014 | 11:48 AM
crossfire_05's Avatar
Default Timing Belt
I heard that all crossfires dont have a timing belt. This true?
Old Jan 21, 2014 | 11:54 AM
sk8erjosh09's Avatar
Default Re: Timing Belt
True, we have a timing chain. Beefy sucker too.
Old Jan 21, 2014 | 11:56 AM
look in my gallery under "What's under the hood"
Old Jan 21, 2014 | 12:01 PM
Gotcha, thanks..
Old Jan 21, 2014 | 12:45 PM
You know the schedule to replace it?
Old Jan 21, 2014 | 01:07 PM
There is no scheduled replacement on a timing chain that runs in an oil bath to my knowledge.
Old Jan 21, 2014 | 01:53 PM
This ^
That and the reason I referred to it as "beefy" is to help clarify the fact that I think pretty much anything else would break first lol.
Old Jan 21, 2014 | 02:00 PM
The day before it lets go!
Old Jan 21, 2014 | 05:58 PM
Hahahahahahahahah!!!
Old Jan 21, 2014 | 06:38 PM
ImportLabSRT's Avatar
Double row chains will last longer than the rest of the engine. If this was a M271 or M111 with a single row, I would check stretch at 100k to be safe.
Old Jan 21, 2014 | 07:15 PM
Toolman's Avatar
I've seen two used crossfires on Craigslist with the sellers stating the timing belt was recently changed. Following that I don't believe anything they are saying.
Old Jan 21, 2014 | 11:02 PM
philosophico's Avatar
Just keep doing your regular oil changes, it will last the lifetime of the car. Chains rarely break but if they do its mostly because the owner NEVER changed there oil. Dirty oil is the enemy of everything.
Old Jan 21, 2014 | 11:12 PM
Bigkid's Avatar
I asked Rudy about this about a month ago. He said he has seen high milage MB engines with these chaines after 200k plus with very little visible wear. The guides and rails are the parts that show wear. He also said if there were to be excessive wear it would present itself with noise you could not ignore long before anything breaks. So if they are not making noise don't worry. Rudy if I misstated this please correct.
Old Jan 22, 2014 | 10:18 PM
Yeah I change the oil every 6000 miles. i been making sure it is all good which it is.
waldig
Jul 31, 2017 09:46 AM
UNDER PSI
Aug 1, 2015 02:11 AM
waldig
Jul 30, 2015 07:39 PM
autumnmass
Jul 30, 2015 01:06 PM
Tp'sfury
Jul 17, 2015 01:15 PM
