"LINEAR" Radio Setting??
Old Dec 11, 2014 | 02:09 PM
eagle670's Avatar
Default "LINEAR" Radio Setting??
Okay, I give up, what in the hell is the linear setting on the stereo system? I know how to access it, but I have not a clue on what it does or how to set it.
Can someone explain it to me?
Old Dec 11, 2014 | 03:19 PM
Default Re: "LINEAR" Radio Setting??
Owner's manual says it effects the 'tone' :
Linear adjustment (LINEAR)
The tone values for the set signal source (e.g., radio/
FM) are set to “0” (mean value). Press and hold the
AUD button for more than 4 seconds until FM LINEAR
appears (which affects FM only). Press and hold
the AUD button for more than eight seconds until ALL
LINEAR appears (which affects both radio and CD).
Old Dec 11, 2014 | 04:24 PM
eagle670's Avatar
Okay. Thanks, I might as well give it a shot.
Old Apr 16, 2015 | 08:39 PM
dejohnny's Avatar
Default Re: "Flt" Radio Setting??
I have no clue what that Linear adjustment (LINEAR) is for, or how to access it. When I Press AUD on my radio, there are four settings that are displayed where I can control the Bass, Treb, Bal and Flt.
What the heck is Flt anyway?
I Suppose I'm trying to adjust the Tone. However, I noticed on the display that the upper level is way over to the left and the lower level is centered in the middle (Right now it TONE FLAT?). How do I adjust this setting?
Normal FM Radio:
https://drive.google.com/file/d/0BzI...ew?usp=sharing
AUD Display
Old Apr 16, 2015 | 09:40 PM
Normal FM Radio:
AUD Display
I believe that is "FLAT", it sets all the tone controls to the middle (Neutral) setting. "LINEAR" is a similar setting as (for audio or RF purposes) "LINEAR" means "a faithful reproduction of the input signal". In other words, "LINEAR" means 'flat'.
You don't have "Linear" but you do have "flat", I believe they are the same thing - only it is called by one term in the NAV head and by the other term in the Non-Nav head.
I would run out to the car and verify this, but I am 770 miles from home on a business trip.
Old Apr 19, 2015 | 11:56 AM
dejohnny's Avatar
It's one of those weird things about this car that I don't quite understand. There's nothing in the my owners manual that describes what or how to adjust this setting.
Does anyone out there know what I'm supposed to do with it?
Thanks pizzaguy!
Old Apr 19, 2015 | 03:45 PM
I BELIEVE that selecting "Linear" or "Flat" will set all tone controls to neutral.
Try it. If it does not, then I don't understand the manual either.
(It is in the audio manual for the NAV head - the NAV units have a separate manual.
It is poorly written in a lot of places - or I am dense and stupid.)
pioneer4x4
Sep 18, 2023 11:49 AM
PNA
Nov 12, 2020 04:44 PM
Bayukbros
Aug 28, 2015 08:59 AM
MAXIMUM
Aug 4, 2015 11:04 PM
pioneer4x4
Jul 27, 2015 02:04 PM
