tinking in motor till car warms up completely Chrysler Crossfire
Old Jul 27, 2015 | 06:27 AM
rperry52@live.com's Avatar
Default tinking in motor till car warms up completely Chrysler Crossfire
Had to replace Relay Control Module Assy. When I start the car sounds like a fast ticking noise like old lifters would. Once warmed up and driven a little noise stops. Any ideas ?? I've owned since new in 2004.
No problems till now 79,000 miles. 2004 Crossfire
Old Jul 31, 2015 | 03:19 PM
Goldwing's Avatar
Default Re: tinking in motor till car warms up completely Chrysler Crossfire
It probably did it before but you just noticed. If the car sits the oil drains out and it ticks for a few minutes until pressure fully lubes the lifters. Mine has always done it and many that I test drove also did it. There is a difference between a tick that goes away and a clatter that stays.
Old Jul 8, 2018 | 03:35 PM
CapnRon's Avatar
When was the last time you changed the water pump...? I can't hear yours obviously... but that description fits inline with how I would describe noise that ended up being the water pump when I thought it was the motor ticking. In essence... the water pump ticking the way it is all connected can indeed sound like the motor ticking. It also went away after driving it a bit it seemed. Was stoked to replace the water pump and realize it wasn't the motor. Just a thought.
Old Jul 8, 2018 | 03:53 PM
And a good thought.
My car has started an odd noise when cold. Sounds to me like a bad rod, or a rod running without oil. Once the water gets to about 180F, the engine sounds fine.
Yesterday, I put an oil pressure gauge on the car (which is how I messed my back up). The numbers I am seeing are consistent with the oil pressure numbers I saw on the two other Crossfires I've owned. So at least I know I don't need a new oil pump or oil pickup...
My next move:
Once my back heals,
1) I will start the car cold and observe the noise.
2) I will then shut the car off, take off the belt and restart the car.
3A) If the noise is still there, I know it is internal.
3B) If the noise is gone, I will put the belt back on and if the noise comes back, it's in a pulley or bearing outside the engine.
I suggest this as your next diagnostic step, Perry. Let us know what you find.
Old Jul 8, 2018 | 07:17 PM
Nunyadam's Avatar
piston slap.
Old Jul 9, 2018 | 06:38 PM
Originally Posted by Nunyadam
piston slap.
That sounds like violence toward an engine.
Old Jul 9, 2018 | 09:32 PM
piston slap.
I googled that.
I can't imagine how my piston could have become "too small for the bore" but what I read does make it all make sense.
Just can't imagine how it ended up this way, so I remain intrigued but not yet convinced.
Old Jul 9, 2018 | 10:02 PM
Nunyadam's Avatar
well I read it here somewhere, but can't find the post.
Old Jul 9, 2018 | 10:05 PM
Nunyadam's Avatar
here it is.
https://www.crossfireforum.org/forum...-start-up.html
M111 engine noise search. which one does yours sound like?
https://www.bing.com/videos/search?q...se&FORM=VQFRML
Old Feb 12, 2019 | 07:52 AM
Ed Mahoney's Avatar
mine has been doing this every once in a while ticking is coming from dash board area I think not engine noise ? Can’t find out what it is either ! Anyone else out there with an idea ???
Old Feb 12, 2019 | 10:06 AM
I have been tinking about this for ages, anyone got any toughts on it?��
Old Feb 12, 2019 | 11:14 AM
Possibly leaves and sticks in the air fan area under the cowl. Does it get louder when you speed up the fan?
Old Feb 14, 2019 | 08:27 AM
Ed Mahoney's Avatar
no it’s a very loud ticking but never last long , not coming from fan or engine . Doesn’t happen all the time , just once in a while ! Never could track it down ! Just glad it only last maybe 10 to 15 seconds & not very often !
Old Feb 14, 2019 | 12:18 PM
JSK's Avatar
JSK
Possibly exhaust components heating up and expanding?
BradenSG
Northeast Forum
Mar 19, 2020 08:52 AM
autumnmass
Jul 2, 2015 10:35 PM
cmnyland5955
Jun 20, 2015 01:24 AM
amx1397
Jun 15, 2015 08:23 AM
Meanberg
Jun 14, 2015 02:25 PM
