Trunk stuck locked with bad vacuum pump
Old Jan 31, 2018 | 12:17 PM
Istrix's Avatar
Default Trunk stuck locked with bad vacuum pump
I've been at this for a couple hours now. Does anyone have any info on getting the trunk open if the vacuum pump is shot from water leakage in the trunk?
here's more info based on the posts I've scoured so far:
1. Doors are manually unlocked, trunk lid is locked.
2. Doors will not lock/unlock with fob
3. Doors will not lock/unlock with dashboard button
4. No sounds from pump when manually unlocking door from driver side with key
5. Using key on driver side does not unlock passenger door.
6. Trunk definitely has water leakage.
I've read some say yes some no that there is a manual release someplace, but does anyone have any concrete info or pics of where such a thing might be located so I can get the trunk open and try to salvage the pump?
Old Jan 31, 2018 | 12:23 PM
Default Re: Trunk stuck locked with bad vacuum pump
I answered the other post you made, you can open it through the tag light. Here is the thread that explains it .CLICK
RogerO
Jun 25, 2021 01:51 AM
Bob_Ham
Jul 21, 2012 10:35 AM
MrFreeze
Aug 21, 2011 10:48 PM
whiskeyfrank
Apr 28, 2008 07:57 PM
jpgp51
Jun 27, 2005 07:29 PM
