Any body know why
Old Jul 31, 2018 | 06:07 PM
Splatfly's Avatar
Default Any body know why
Hi all, anyone know why my new/secondhand replacement alarm works different than how everyone else has described. I followed the thread describing how to replace and with what but mine seems to work opposite with regards to the chirps. It chirps three times to unlock and nothing to lock. Everything seems to function as should ie. sounds when disconnneted or deliberately set off, sets and does not go off unintentionally. Any ideas, thanks.
Old Jul 31, 2018 | 08:44 PM
Default Re: Any body know why
That alarm is the one issue Iv'e never had to deal with.
Cant wait to see what responses you get.
Old Jul 31, 2018 | 09:47 PM
Speedy4x4's Avatar
I haven't had mine hooked up since I purchased at 50k miles, have not had a interest in hooking it up.
did wires get crossed when installing ?
Old Jul 31, 2018 | 11:49 PM
Did you replace it with a compatible alarm, maybe you got the wrong replacement.
whst part number did you put in the car?
Old Aug 1, 2018 | 09:18 AM
Splatfly's Avatar
Hi no chance to cross wires the plug only fits one way.
Old Aug 1, 2018 | 09:22 AM
Splatfly's Avatar
A1718202526 Which was the same as was on it but did not work due to the batteries leaking acid on to the board.
Old Aug 1, 2018 | 09:45 AM
The beeping is controlled by the security pump in the trunk, the siren itself is pretty dumb. The pump tells it what to do.
That is my understanding, do you have water in the well where the pump sits? Stick a taper of newspaper down the gap between the foam and the well side.
Old Aug 1, 2018 | 12:56 PM
Splatfly's Avatar
Hi and thanks but no water down there had the whole well thing stripped down foam out the lot to see before I found out about the batteries leaking acid. Everything was dry as a bone and no signs of water.
Old Aug 3, 2018 | 07:13 AM
Ed Mahoney's Avatar
When I replaced mine , new one has chirp .
Thirteendog
Aug 19, 2008 04:00 PM
Jan 23, 2008 10:13 AM
andrew
Other Cars Etc
Jun 28, 2007 11:12 PM
andrew
Other Cars Etc
19
Mar 27, 2007 12:58 AM
