Speaker advise
Old Sep 11, 2018 | 11:38 PM
Irekunso's Avatar
Default Speaker advise
Can anyone here give me an idea on which subwoofers I should get to replace the stock ones behind the seat.
Old Sep 12, 2018 | 02:45 AM
Default Re: Speaker advise
Start reading:
https://www.crossfireforum.org/forum...rear-subs.html
Old Sep 16, 2018 | 09:43 AM
Tbirdtony's Avatar
Irekunso, I'm not an audiophile so I rebuilt the subwoofers in my 04 Crossfire (easy to do). I'm very happy with the sound from the original stereo 04 Crossfire. Maybe a rebuild of the subwoofers is all you need.
Old Sep 16, 2018 | 12:05 PM
Irekunso's Avatar
Ok. Thanks. Good idea.
Old Sep 16, 2018 | 02:07 PM
RED DOG's Avatar
Look here: https://www.crossfireforum.org/forum...tml#post908886
Old Sep 16, 2018 | 06:54 PM
STRANDD's Avatar
Also, do the Biggest stereo bang for the buck mod found on the forum. Easy to do and works wonders on pumping up the sub woofers.
Old Sep 16, 2018 | 11:18 PM
I will have a bag of the capacitors at the Dragon that maxcichon gave me, anyone needing a pair, see me.
Old Sep 26, 2018 | 06:14 PM
Irekunso's Avatar
I have a 2005 XF. I put in a new receiver and just purchased a new set of component speakers for the doors. I have a high quality powered sub that I will be using. I am considering using the stock amp to power the doors only and not even using the two small subs behind the seats. What do you think?
Old Oct 1, 2018 | 05:54 AM
Speedy4x4's Avatar
On head unit, set the frequency on the high pass filter to 100 - 150 hz and sub to match.
my hpf is set at 100 hz an lpf at 120 hz.
Your subs behind seats will nit go as low and sound goid, when using your powered sub.
I am using factory amp pushing 6.5's behind the seat and skar components with tweeters on dash by a pillars and oem tweeters also, with skar class d amp powering a pair of zvx 8's and plenty of room for luggage every week.
Old Oct 1, 2018 | 12:25 PM
Irekunso's Avatar
Ok. Thanks. That's what I needed to know.
Old Oct 1, 2018 | 04:19 PM
Speedy4x4's Avatar
np, glad I could help.
I don't know what head unit you have but most aftermarket head units you can change the lpf and hpf.
as I said I am running 2 pairs of tweeters and love it.
oem in oem spot and the component tweeters on dash, thought about cutting them in the a pillar, but I like the positioning in reference to driver seat atm.
​​​​o, I think I left the tweeters plugged in as normal, and the component tweeters on the crossover with the component set, and the wires that went to door speaker going to the crossover.
I have a thread about it and how I mounted the crossover somewhere.
Old Oct 1, 2018 | 09:38 PM
Irekunso's Avatar
Great idea. I have never thought about using a second set of tweeters before. I also have never used a set of midbass subs like the ones behind the seat because I have always used a powered sub for bass. It always seemed pointless. I am considering using a set of new Polk 6.5 two ways behind the seat that I have never used. Thanks.
Old Oct 1, 2018 | 09:57 PM
Speedy4x4's Avatar
I have a awesome pair of audiobahn 6.5 but the magnets are to big.
One day, I will install some 6x9 's behind the seat.
just need a set that the magnets will fit in the hole and make a small spacer to space out the 6x9.
​​​​​​​and every else I have is skar audio, so will probably get those if they will fit, just always something going on.
Old Oct 1, 2018 | 11:34 PM
Irekunso's Avatar
I also have a set of Rockford Fosgate Punch 4 way 6X9s (P1649) that I have new in the box. Bought about a year ago. I don't think they will fit without cutting a larger hole. As soon as my son comes back in town with the car I will check and let you know.
Pjj51
Oct 9, 2016 07:55 PM
Extensive
Oct 23, 2006 12:59 AM
lilb93
Aug 31, 2006 11:44 PM
golfergal
Jun 17, 2006 12:20 PM
jokers777
Jul 29, 2003 10:39 AM
