Lack of acceleration/rough idle
Old Jun 24, 2005 | 02:35 PM
artz105's Avatar
Default Lack of acceleration/rough idle
I have had my 2004 automatic coupe (4400 miles) at the dealer 4 times since mid-April and will be going back again on Monday. I'm actually having 2 problems: 1) unpredictable lack of acceleration (NO acceleration at all for several seconds, then 1-6 MPH) after coming to a complete stop and 2) periodically when stopping at a light, the engine will start to "miss", subtly at first, then violently shaking the entire car. This can be relieved by either putting the car in park OR by turning off the AC. Of course this can never be duplicated at the dealership, though they have been very conscientious in their efforts--no complaints there. Has anyone successfully had the same/similar problem solved?
Thanks.
Old Jun 24, 2005 | 03:23 PM
REDSC400's Avatar
Default Re: Lack of acceleration/rough idle
Well, this does not sound good. What are the RPM's when it is running right vs. when it is acting up? Is the lack of acceleration present all of the time?
You may have a bad sensor, or even a bad fuel pump or clogged fuel filter / injector...
or...
perhaps the automatic trannie is staying in a top gear fully engaged when you are at idle this would account for the engine vibrating as well as poor acceleration when you take off.
Have you tried going into "neutral" when this happens to see if that would cause the symptoms to stop?
When did this all start?
Have you checked your trannie fluid level?
What fuel are you using BTW? Octane?
You may want to throw in a bottle of Chevron Techron fuel system cleaner into a 1/2 full gas tank and run the tank down. It will clean up your injectors and to some extent the sensors.
Old Jul 4, 2005 | 01:27 AM
babeviper's Avatar
Thanks.
that is the same problem, my car had twice and both times it turned out to be the mass-air sensor probe. the car was shooting a code that the tech's could not figure out. so, they call the tech rep at chrysler and that fix the problem. the mass-air sensor probes have had alot of faults from all german cars. hope this helps bud!!!
Old Jul 4, 2005 | 02:12 AM
John Webster's Avatar
My manual '04 coupe shakes from side to side at idle when the temperature is above about 70ºF. The dealers mechanics won't even acknowledge that the problem exists.
If I ever find a dealer who will work on the car and not do more damage than the fix... I'll mention the air mass sensor.
blackpepper
Racing
16
Sep 27, 2015 01:38 AM
ozkancab
Sep 25, 2015 10:55 AM
velociabstract
Aug 28, 2015 11:20 PM
toob
Aug 19, 2015 07:31 AM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
