Going to look at a 04 manual with 105k
Old Apr 28, 2023 | 02:32 PM
RobertV's Avatar
Default Going to look at a 04 manual with 105k
Anything "special" to look at specific to the CF/CLK? Waterpumps one item correct?
Seller says AC compressor is bad, but everything else is good.
TIA
Old Apr 28, 2023 | 03:17 PM
Default Re: Going to look at a 04 manual with 105k
Compressors seldom go bad, be prepared for the chance the A/C issue is sensor/electrical in nature. There are a LOT of reasons the ECU will not engage the A/C pump.
Also, know that a clutch will run you $900-1500 so if the clutch is grabby or really worn, keep that in mind.
Read thru some of the "Sticky" threads here with titles that indicate information for buyers:
https://www.crossfireforum.org/forum...introductions/
Old Apr 28, 2023 | 05:30 PM
RobertV's Avatar
Thank you for your response. Reading now.
quejersey
Nov 4, 2014 06:22 AM
bluemax
Oct 14, 2010 05:51 AM
srt8guy
Jul 20, 2009 11:40 AM
wheelhouserocker
Midwest Forum
Mar 3, 2008 08:56 AM
BillP2R
May 3, 2007 11:23 PM
