heater motor wont operate
Old Feb 15, 2006 | 09:10 PM
crossfirefun's Avatar
Default heater motor wont operate
Like the title says. When I parked it, it was working fine. Now it won't turn on no matter what I try. Fuse is o.k. any ideas?
Thanks
Old Feb 15, 2006 | 10:24 PM
typhoon55's Avatar
Default Re: heater motor wont operate
Thanks
Did you put a volt meter on it? Did you test it? Are you getting power at both ends?
Old Feb 16, 2006 | 06:31 AM
I haven't had a chance to check anything yet. It was working when I parked it so why should it stop now?
I will do more checking tonight after work. I was looking for info on what relay to check for. Also where is the motor located on this car and can the wiring be accessed?
Old Feb 16, 2006 | 09:25 AM
typhoon55's Avatar
Check the blower motor regulator located behind lower right instrument cover. There is a blue and red wire attached to regulator. Check if it has power, these electrical leads are a one way connection to blower motor.
Old Feb 16, 2006 | 04:00 PM
Thanks for the info. I checked the wires and had power. I removed the next cover and was able to access the motor. It was stuck, I got it to turn and now it works fine. Hopefully if this happens to anyone else they will now know how to fix it. Only two screws and two slip connectors to access motor.
Thanks again
Old Feb 16, 2006 | 05:33 PM
typhoon55's Avatar
Hey mon no problem - I wish they were all that easy!
I am curious how it was stuck - was there something obstructing?
Old Feb 16, 2006 | 06:03 PM
stryfox's Avatar
I had a similar problem, some leaves made there way down there and were making an awful noise. Easy fix, good design.
Old Feb 16, 2006 | 06:38 PM
didn't seem to be anything there it was just like it was welded stuck. no noise like anything is rubbing and no debris fell when I turned it.
Old Feb 16, 2006 | 07:48 PM
stryfox's Avatar
The electric motor brushes probably we not making contact. When you spun it by hand they did. This can happen with most electric motors once in a blue moon.
If It doesn't happen again I would just forget about it.
Glad it was an easy fix.
Old Feb 16, 2006 | 08:26 PM
FirebaseD's Avatar
Yes my blower motor was not working properly no more then three or four days ago. I beat on the dash, above the glove box door or there abouts, and it started operating like nothing had ever happened. Go figure. Only problem with beating on the dash in that area is the air bag, hooah?
Old Mar 30, 2008 | 03:29 PM
Cadetgray's Avatar
Once again, this forum has saved the day! I, too, had a blower that just stopped working the other day for no apparent reason. There was no "leaf blower" sound (I used to have that ALL the time in a '90 Saturn SL2). But a quick search of this site and voila I got it working again by following the instructions to just spin the blower. Thank you Thank you
franklindm
Mar 14, 2020 12:23 PM
Apr 28, 2016 02:04 AM
Nov 11, 2015 05:22 AM
Oct 1, 2015 01:42 AM
Billy22Bob
Sep 26, 2015 10:16 PM
