do all XF bog out???
Old Mar 3, 2006 | 11:39 AM
+fireamx's Avatar
Default Re: do all XF bog out???
Originally Posted by Napasanaoma
I have an auto stick and it will hesitate if the traction control is on and I horse. The tires are trying to break loose, so turn it off and you will be surprised.
On the manual stick it has an RPM limiter, I think 4,000 RPM, this is if you try to rev it up prior to releasing the clutch. Its all in the manual.
Mark, I know about the rev. limiter. HDDP and I talked about it in a previous thread a while back. Besides, I wouldn't launch my car that hard anyway. I don't believe in abusing my cars, just enjoying them.
I was talking about breaking the tires loose even with the traction control turned off, and the darn TC let's you spin a little, then still shuts you down.
If you do a search on traction control, there's a whole thread about turning it off by removing a fuse, or getting a chip, everything I don't want to do.
Thanks for your input...Mike
Old Mar 4, 2006 | 12:01 AM
xfire1's Avatar
OK HEAR IS MY UPDATE. THE ROADS HERE ARE STILL TO ICY TO GET ON THE xf TO DUPLICATE THE PAUSING EFFECT... HOWEVER I JUST WANTED TO COMMEND THE PERFORMANCE OF MY XF IN THE SNOW AND ICY CONDITIONS...
I LOVE THIS MACHINE...
J.
Old Mar 4, 2006 | 02:15 AM
HDDP's Avatar
Originally Posted by xfire1
Just wondering if the other 3.2 engines are doing the same... When i punch the accelerator to the floor from a dead stand still... immediately the force presses me back into my seat... hard... the rear end drops the nose lifts and i am in the middle of take off...
HOWEVER... EVERYTIME IN THIS MODE... THE CAR SUDDENLY YET MOMENTARILY HESITATES...1/2 TO ONE SECOND.... LIKE THE WORLD STOPPED AND ALL YOU HEAR IS SILENCE AS THE NOSE DROPS BACK DOWN ...THEN IT KICKS BACK IN LIKE A BAT OUTTA HECK... AND ITS GOOD TO GO WITH NO MORE BOGGING FROM THAT POINT ONWARD... IT IS ALWAYS FROM THE LINE THAT THIS OCCURS.
Is this typical of the CROSSFIRE?
Years back I had a E320 that also did this so?!?!?!
Thanks in advance for your output...
J.
Just a guess, but it may have to do with the "drive by wire"... no direct linkage to the Throttle body... IMHO...
Old Mar 4, 2006 | 05:54 AM
Napasanaoma's Avatar
Xfire1,
I have drove my car in the one snow storm we had, the only way I could get up my driveway was to turn of the traction control and put the s/w in s. I have also took off floored from a stand still and there is a difference between no traction control and with. I have had it seem to almost stall especially when it is wet outside, and you accelerate to hard.
Old Mar 4, 2006 | 05:56 AM
Also HDDP if what you said was true, I would expect to see this when I would floor it to pass another car and it is smooth, I do not see any hesitation at all. What about when you race the peddle must be to the metal alot?
Old Mar 4, 2006 | 08:11 PM
xfire1's Avatar
HDDP i found an old post of yours... where you state a procedure of "resetting" the computers settings without disconnecting the battery... so i tried that... and it CURED MY HESITATION from a dead stop... makes alot of sense that you do this before prior to your race heat as you stated...
Thanks doc! I mean ...HDDP !!!
Old Mar 5, 2006 | 12:30 AM
cross1's Avatar
Could you possibly link that computer reset thread... I looked high & low for it? I have had the same problem - intermittently feels like the fuel supply shuts down for a split second, then ok. ???. Thanks in advance.
Carl
Old Mar 5, 2006 | 01:44 AM
xfire1's Avatar
Carl
Carl... i forget the thread i found it on but i saved it to word...
as HDDP stated:
Throttle Body Adjustment. They say this works on all drive by wire vehicles and resets parameters WITHOUT Having to disconnect battery!
The Throttle is "Drive By Wire" and adapts to your particular driving
style. Do a TBA Throttle body adaptation.
1. Get in your car, it doesn't matter if you close the door or not.
2. Turn the key to the on (not start) position, the position just before the starter
turns over.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back
to the "off" position (don't remove the key), then release the gas
pedal.
5. Wait 2 mins. for a full alignment.
6. Drive the car as you always do.
Depending on your driving style, this may or may not be a big factor. I do a lot of city driving so
I noticed a big change after erasing my history. It is not hard to do this, just follow the instructions -
Key on, pedal down, 5 sec, key off pedal up, wait 2
minutes.
Keep the key in for the entire thing.
If this doesn't work, disconnect your neg. battery cable for 20 minutes. This will re-set the parameters in the drive-by-wire... Unfortunately it will delete your pre-set radio stations, clock etc. as well...
thanks again HDDP
j.
also NAP there are different load ratios/factors when the car is at a stand still versus a car moving at 30, 40 or 80 mph...
Old Mar 5, 2006 | 01:03 PM
cross1's Avatar
xfire1.
thanks, carl
Old Mar 5, 2006 | 10:56 PM
xfire1's Avatar
cross1 did you do the reset process???
Old Mar 7, 2006 | 12:18 AM
cross1's Avatar
Not yet, xfire is still sitting under the tent. Its supposed to be warm this weekend. Maybe then.
Carl
Old Mar 14, 2006 | 01:38 AM
xfire1's Avatar
cross1... did you try the sequence yet? it took me 3 times to get it straight.
j
n8randall
Nov 9, 2013 04:31 PM
KROSSFIRE1988
May 26, 2013 12:39 AM
stevieb
60
Sep 1, 2010 03:36 PM
Teck-9
Aug 27, 2010 01:48 PM
Cincinnati Slim
Racing
Sep 3, 2007 03:45 PM
