Audio in Trunk
Old Oct 5, 2006 | 03:51 PM
nitro4's Avatar
Default Audio in Trunk
Anyone here own a roadster with some sort of bass setup (like a sub box) in their trunk?
I've been told that the vibrations won't get through to the cab (passenger) area due to a metal sheet between the seats and the trunk in the xfire roadster, but i want to hear what you guys have done if you've gotten any extra oomph.
Old Oct 5, 2006 | 04:13 PM
spensley's Avatar
Default Re: Audio in Trunk
Check out this thread...
https://www.crossfireforum.org/forum...t=11786&page=4
I suggest you contact Cyril Baldwin.
Old Oct 5, 2006 | 04:15 PM
nitro4's Avatar
He has a coupe not a roadster.
Old Oct 5, 2006 | 05:43 PM
coony3737's Avatar
i'm planning on doing a setup in my '05 roadster and my buddy (who has a car audio business on the side) seems to think everything would be fine.
Old Oct 5, 2006 | 05:54 PM
nitro4's Avatar
here's the problem...
i need to find subs that are thin enough to fit underneath the roof hatch for the roadsters, because i want the box to slide in under there... most subs i've seen have been pretty deep, i know there are rockford p1 10 inches but they are WEAK!
Old Oct 5, 2006 | 05:56 PM
nitro4's Avatar
i'm actually thinking maybe i should go with dual 200 watt 10" bazooka subs in the trunk since they're thin profiled and i could fit the underneath... but quality probably won't be too great.
Old Oct 6, 2006 | 08:13 AM
crossfirefrank's Avatar
I installed a 10" kenwood sub in my trunk and it works great. I jumpered the top cover micro switch so I could leave the top cover in the folded position which seems to help. The only problem I have is my wife complains about no trunk space. It's not that big of deal, we only use the car for pleasure on nice sunny days.
Old Oct 6, 2006 | 12:25 PM
nitro4's Avatar
thanks! please tell me how much you can feel the small 10" sub in the cab? does it really make a difference? just a 10" ? also, do you think i'd be able to fit two if i wanted to do the same thing, i'm assuming they're kenwood p1's ?
Old Oct 9, 2006 | 08:28 AM
It is a kenwood 10" tube sub. No you will not be able to fit two across, not enough width. But they do add a lot of lower bass.
Osusannah
Feb 12, 2024 01:49 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
Reliableron
Oct 17, 2015 10:19 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
xjken
Sep 13, 2015 10:18 PM
