Fog lights?
Old Jan 28, 2007 | 11:43 AM
Gwetoe's Avatar
Post Fog lights?
Has anyone installed aftermarket fog light kits on their crossfire? If you have what are the problems and to work out and the instructions on how to install/wire the kit to work via the "fog light" switch already in the headlight mechanism and the dash. I ask this only because I want to put them in if I do not have to put some crappy after market toggle switch on my dash. Any help would be appreciated.
Old Jan 28, 2007 | 12:30 PM
GatorLCA's Avatar
Default Re: Fog lights?
You can probably get OEM ones for fairly cheap. I can't see them excluding the Fog Light electrical lines in the electrical assembly, btu they could have. Check to see if there is a plug within the bumper where the fog lights should be. If there's a plug then you can just get factory ones and take out the plate blocking off where the lights should go.
Old Jan 28, 2007 | 12:33 PM
Gwetoe's Avatar
I'll go and take a look at the bumper now and see what I have.
Old Jan 28, 2007 | 02:07 PM
Gwetoe's Avatar
Nope...no wire or anything down there with the exception of the outside temperature sensor.
Old Jan 28, 2007 | 06:16 PM
wocar's Avatar
https://www.crossfireforum.org/forum...ead.php?t=7348&
xfireohio
Jul 20, 2020 12:03 AM
Adrian_X
Nov 9, 2017 08:49 AM
maxcichon
Jul 8, 2016 08:28 AM
pioneer4x4
Sep 24, 2015 11:17 AM
KwehCat
Jul 16, 2015 04:48 PM
