battery keeps going dead HELP !
Old May 12, 2020 | 03:13 PM
Default Re: battery keeps going dead HELP !
Originally Posted by glvicik
I don't think I would have thought to do this step by step procedure on my own. Again, thanks so much.
You are welcome, I like it when people LISTEN, it does little good for me to put effort into helping people when they wont even try - you tried, you learned and now you know what was wrong with your car!
As to the procedure, this is the kind of stuff I've been doing for a living since 1982.
Old Sep 5, 2020 | 10:09 AM
stevet340's Avatar
I'm having a similar issue with my 2005 limited. I was driving it and I couldn't lower the radio volume and I couldn't shut it off. Went to drive it 2 days later and the radio didn't turn on. Wasn't too worried about it. The next day the battery was dead. I did the diagnostics you suggested but found everything is ok. What would you suggest I do from here as I don't want to be stranded? The battery is less than a year old.
Old Sep 5, 2020 | 10:51 AM
I would remove the fuse for the radio and see if that helps since you know it has been acting strange. It sounds like a short.
Old Sep 5, 2020 | 01:16 PM
You have what is the most difficult issue to resolve: An intermittent electronic failure. That is, based on what you typed, the radio is acting up in such a way that it does not always turn off, taking the battery down. Since this is all I know about the car, I'd replace the radio right away. That, or yank BOTH fuses to the radio and give it a few days - if the battery goes dead again, you know there is something else wrong.
But the symptoms you talk about are similar to how my factory radio died. For $85, a new JVC from Best Buy was the best move I could make - and it sure sounds better than the old factory head.
Old Sep 5, 2020 | 01:23 PM
I didn't realize there were two fuses for the radio? One for the radio and one for the amp?
Old Sep 5, 2020 | 01:36 PM
One fuse is the battery feed to the radio (provides constant power for memory support, etc.)
One is the accessory/ignition feed (tells the radio when the key is on).
There is an additional fuse to power the amp.
The exact location/fuse numbers vary a bit by trim level and year, I believe.
blackpepper
Oct 4, 2017 06:09 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
