8.5 quarts of oil into an 8 quart vacuum can...
Old May 9, 2008 | 05:08 AM
popeye's Avatar
Question 8.5 quarts of oil into an 8 quart vacuum can...
My Big Boy Top Sider came n I notice its capacity is 2 gallons. Do I need to pour out some oil from my Topsider to get that last half quart in, or does it turn into a blivit
Blivit = 10 pounds of stuff in a five pound bag...
Old May 9, 2008 | 05:44 AM
imabenz's Avatar
Default Re: 8.5 quarts of oil into an 8 quart vacuum can...
My experiance and a few others on the forum has been that you will not get all 8.5 qts out. Its been reported that just under 8 qts. get removed. I can confirm this from my first oil change.
The reason I know this is that it took exactly 8 qts of new oil to re-fill it.
With that being said, I would still be prepared for a small bit of overflow just in case.
BTW, I drained my oil from the drain plug on the oil pan and not with a top-sider. Top-sider users have reported the same thing.
Hope that helps.
Good luck....
Old May 9, 2008 | 05:49 AM
RPM's Avatar
RPM
Moderator
If your topsider starts to fill up, stop the flow and empty it. Then you can start over. That is what I do (mine is only ~6 quart).
Old May 9, 2008 | 08:10 AM
AlG's Avatar
AlG
I don't even think I got 8 quarts out. The filter sucks up some and there's always some left in the pan and I figure no matter how good the engine is over 7000 miles some of it has to get burned. Only took 8 quarts to refill when I did the oil change...also from the bottom.
Old May 9, 2008 | 09:34 AM
buff5's Avatar
Only got 3700 miles on my 06 so far but this is my question , is the bottom drain plug easily accesable behind the large plastic air managemnet cover?, I never looked yet.
Old May 9, 2008 | 09:39 AM
imabenz's Avatar
I was able to reach it without jacking up the car. I have long arms, I'm 6'2". There is not much clearance under there. Make sure your oil pan can fit and that it can hold 8 qts. Most folks mention that they jack up the car. But it can be done without being raised.
Old May 9, 2008 | 10:09 AM
buff5's Avatar
THANKS VERY MUCH!!!!!!!!!!!!!!!!!
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Billy22Bob
Sep 28, 2015 08:08 PM
Sep 28, 2015 07:40 PM
