What do you know about that...
Old Nov 8, 2008 | 10:22 AM
gibsonjunkie's Avatar
Default What do you know about that...
I was under the dash checking out my iPod interface which was making noise and found it was soaking wet. Apparently there is a leak somewhere under the dash. I think the guy who replace the windshield didn't do a very good job...
Well, anyways, while I was under there I pulled the cover on the cabin air filter, which the base roadster wasn't supposed to have installed, and what do you know - there was filter in there - pretty dirty and loaded with dead leaves... hm-m-m... got a new one and it popped right in.
Old Nov 8, 2008 | 10:42 AM
oceans2c's Avatar
Default Re: What do you know about that...
Where exactly were you? I have a base roadster as well and did not see anything obvious, that I could pull on. The passenger side has a cover leaving nothing exposed and requires a phillips. Drivers side hemmed up as well???
Old Nov 8, 2008 | 11:43 AM
Two philips screws hold a rubbery platform behind the glove compartment. When you drop that you expose the air filter housing. Do a search on this forum, I think someone once did a swap with pictures, at least they described it. It took five minutes - real easy!
Old Nov 8, 2008 | 01:29 PM
Iamfink2's Avatar
Check out this link https://www.crossfireforum.org/forum...t=23022&page=2 post #39. This is what I found when installing my new alarm siren it may be where your water came from.
Old Nov 8, 2008 | 01:57 PM
oceans2c's Avatar
Hmmmm. tools.
Guess the laptop is headed to the garagy.
thanks
Old Nov 8, 2008 | 05:47 PM
sonoronos's Avatar
IF you have dead leaves in your air filter, make sure you unscrew the base to the blower motor and clean it out. I can almost guarantee you it has junk in there.
Old Nov 11, 2008 | 04:10 PM
Thanks. I'll do that. I pulled the iPod adapter - let it dry out and hit it with some tuner cleaner. I reinstalled it the next day and it worked great!
Haven't had time to check the leak...
JHM2K
Jul 14, 2014 05:43 PM
lildaddym
Jun 8, 2013 02:22 AM
SrWilliams
Jan 16, 2013 06:58 PM
waylander
Nov 9, 2012 09:18 AM
Kolme
Sep 11, 2012 09:58 AM
