Need Some Help... Noise In Reverse.
Old Dec 16, 2008 | 08:43 AM
Steven 4190's Avatar
Default Need Some Help... Noise In Reverse.
Hello All,
Since day 1 of owning my 2008 Roadster, there is a metal crackling sound whenever I am parking and turning my wheel in reverse. This noise is only when in reverse. Anyone else experience this metal crackling noise? Any ideas as what it could be. I am very reluctant to take it in to the dealer. They are clueless and will muck up something else for sure. Thanks.
Old Dec 16, 2008 | 09:07 AM
aftcg's Avatar
Default Re: Need Some Help... Noise In Reverse.
Where's the noise coming from? Front, back? Does it only happen when reversing while turning the wheel? What if you turn the wheel, go reverse, and don't add or subtract steering inputs? We need to figure out if it is a steering or suspension thing.
Old Dec 16, 2008 | 09:25 AM
maxcichon's Avatar
I see you have after market wheels. How carefully did you select the length of the new lug bolts? Maybe they are touching the e-brake springs inside the rear hub assy.
Maybe?
Thanks for the quick response. The noise comes from the front & when turning the wheel.
Old Dec 16, 2008 | 09:29 AM
The noise was there before I installed the wheels. I did have to purchase a shorter lug due to the interference with the emergency braking system. Thanks for the help.
Old Dec 16, 2008 | 11:27 AM
Bladecutter's Avatar
Originally Posted by Steven 4190
Hello All,
Hi, I would check the condition of the engine and transmission mounts first if the sound occurs when the vehicle is changed from one transmission position to the next. Getting the car up on a jack would be the easiest way to do this.
BC.
Old Dec 19, 2008 | 03:39 AM
REVIT93RX7's Avatar
If it occurs when turning the wheels then I would suspect an interference problem.
Old Dec 20, 2008 | 08:37 AM
marcossaito's Avatar
hi steven,
i hear the same in my 05 roadster but i could not associate it to any other condition like turning the steering wheel or not. and it does not happen all the time. i have driven my car for around 4 months and have not noticed anything strange. just do not give it that much attention anymore.
cheers.
ty_ty37
Jun 27, 2024 10:42 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
pop49
Sep 30, 2015 11:14 AM
RacerXofFL
Sep 15, 2015 05:00 PM
