Roadster Rear window problem.
Old Jul 15, 2009 | 11:06 AM
tighed1's Avatar
Default Re: Roadster Rear window problem.
Originally Posted by nate_man
I have no suggestions on a fix other than considering a pop-top to keep her cool during and after the fix.
These little covers help keep our rides cool as they really heat up under the sun!
Got one after the repair. Use it everyday at work. Sure it helps.
Old Jul 17, 2009 | 01:27 AM
tighed1's Avatar
Posted pics today of repaired window/top here...
https://www.crossfireforum.org/forum/crossfire-roadster/35189-roadster-rear-window-stick-up-2.html#post396704
Sorry to duplicate but with multiple threads on the same subject, ya know...
Old Jul 17, 2009 | 04:25 AM
sooner's Avatar
Did they ever fix the window problem on the later models? I did do a search but didn't see anything.
Old Jul 22, 2009 | 10:12 PM
Sewngo's Avatar
Here is some info on these tops.As you all know they are on indefinite back order.The tops need to be replaced the quick fix repairs will probably not hold up long.The reason there are no aftermarket tops easily available is that this top has unique plastic retainer trim pieces that hold the top on the frame.Aftermarket top makers cannot duplicate these pieces.Right now whats being done is we can remove the top from the car and send the top to the aftermarket top factory.They take the old top and harvest the trim pieces and the backglass and make a new top with a better bond area design on the glass.The top job comes out very nice and looks completely OEM but with a better glass bond.The only downside is TIME!.The top is gone 2-3 weeks to get done.!Here is some pics.
Old Jul 23, 2009 | 11:03 AM
stan37's Avatar
FOUND!!!! A manufacturer of replacement top for roadster. My window fell out and it's still under warranty. As of today, Chrysler will re-emburse dealers for top if they need to go to aftermarket. This company uses OEM fabric and stats. Check out at this link.
Convertible Tops and Convertible Top Parts
amx1397
Jan 24, 2016 02:12 PM
stlas69
Sep 3, 2015 10:28 AM
xzmilan
Jul 22, 2015 10:40 AM
Buchacho
Jul 9, 2015 04:13 PM
turboomni08
Jul 7, 2015 11:48 AM
