Where to buy multipurpose tool
Old Aug 2, 2009 | 09:42 AM
autumnmass's Avatar
Default Where to buy multipurpose tool
I have a question regarding the "all purpose" tool which was referenced in the manual as being in the glove compartment. I recently purchased a used 2007 Roadster from a dealer but I cannot find one or any other tool in the glove compartment or trunk. Would this tool be available at a local auto store or do I need to order it from dealer.
thanks
Old Aug 2, 2009 | 10:01 AM
Default Re: Where to buy multipurpose tool
thanks
Try looking in the pocket on the bulkhead behind and between the seats
This is what they look like, two variations shown. They must cost all of $1 to make, they are pretty thin.
Dan should make them and sell them at $50 each. Group buy anyone?
Old Aug 3, 2009 | 12:52 PM
turkeyman's Avatar
I purchased one from Chrysler, part # 5140795AA As with everything Mercedes its expensive 187.00
It is basically a 10mm Flat wrench 12inches long with a flat screwdriver end. Your manual tells how to use tools other than it.
If it had not been a prepaid order and I saw what ot was I would have not ordered one.
Old Aug 3, 2009 | 01:33 PM
Valueable information, thanks! I have a 10mm wrench and have already used a flat blade screwdriver to remove the front grill pieces. Don't think I need a $180 part.
Old Aug 3, 2009 | 04:21 PM
Its probably is a Mercedes part and Chrysler marks it up a lot, like usual.
Old Aug 3, 2009 | 06:15 PM
Try looking in the pocket on the bulkhead behind and between the seats.
YOU PEOPLE HERE KNOW IT ALL!
Brought my car home four weeks ago today, just now found mine in THAT VERY POCKET!
(It was in the bag, unopened - just as I would suspect with the guy who owned this car first).
Old Aug 4, 2009 | 03:22 PM
hcarter's Avatar
Cool Re: Where to buy multipurpose tool
YOU GET CAUGHT OUT IN THE RAIN AND THE TOP DOWN AND NOT WORKING ,,YOU WILL WISH YOU HAD ONE HAPPENED TO ME AND IT SUCKS ! WRENCH HAS TO BE THIN TO GET BETWEEN THE PANELS TO THE NUT TO LOCK OR UNLOCK.... ALSO NEED A SMALL SET OF ALLEN WRENCHES TO UNLOCK THE BACK WINDOW.....SPEAKING FROM A BAD EXPERENCE>>>>> CHRYSLER DEALER HERE WHERE I'M AT HAS THEM FOR 145.00 .
Old Aug 4, 2009 | 05:35 PM
This is what they look like, they are .13" thick (1/8") and the wrench opening is .400" (10mm)
If you can find a cheapo wrench of these sizes at a auto or bicycle shop you are in business. A 3/8" (.375") wrench could be filed easily to the correct size. Bicycles used to have wrenches like this in a tool kit.
Drivers of convertibles should have one for sure, anyone else can use a screwdriver for the auto transmission release and the front grille removal.
Old Aug 11, 2009 | 02:21 AM
Tommy's Avatar
Did you ever locate a multipurpose tool ?
Old Aug 11, 2009 | 03:36 PM
autumnmass's Avatar
I just wanted to thank everyone for their help--I found the multipurpose tool in the trunk. Best forum ever!
Old Aug 11, 2009 | 03:48 PM
...anyone else can use a screwdriver for the auto transmission release...
Huh?
Old Aug 11, 2009 | 04:05 PM
Huh? [/left]
From the drivers manual.
With a malfunction in the vehicle’s electrical system, the
selector lever could remain locked in the PARK position.
To unlock the selector lever manually, insert the end of
the multipurpose tool from the glove box (or ball point
pen) into the covered opening below the position “D” of
the shift pattern. While pushing the tool down, move the
selector lever out of the PARK position. After removal of
the tool from the opening, the cover will not close fully.
Only after moving the selector lever to the “D+” and
“D-” positions does the cover return to its closed position.
Old Aug 11, 2009 | 04:10 PM
I have read thru the owner's and navigation manual several times (kept both in my bathroom for almost a MONTH!!) and don't remember reading this.
I DID read about "limp home mode" or something like that, where if the controls fail you will have reverse and 2nd gear only, but didn't see this!
Old Aug 11, 2009 | 04:12 PM
///SilverSaphRT6's Avatar
Where can I get a multi tool set......basically all the air tools but preferbly power ones? The whole nine of garage parts I would need to work on a car. I would like a whole kit and not piece parts here and there.
Old Aug 11, 2009 | 05:33 PM
You can say that again. I cannot believe the amount of information that is here. About 4 out of 5 times, I don't even ask my question, the search function finds it for me.
Old Jun 22, 2012 | 10:10 AM
Indelibility's Avatar
Bringing this back from the dead!
I was trying to remove my windshield wipers to clean out my clogged washer jets (failed, need a better puller), when I spotted something round under my windshield. I grab a screwdriver and after a few attempts, pry it out. Lo and behold, it's the multi-tool! Just goes to show they can be hidden anywhere, mine just happened to be sandwiched between the dashboard and windshield, looked all over for that damn thing too. Feels good to save $100+ :razz:
Old Jun 22, 2012 | 10:28 AM
autumnmass's Avatar
Glad to hear your found it.
Old Jun 22, 2012 | 10:31 AM
turkeyman's Avatar
MultiPurpopose tool can be bought at Chrysler, but is very expense, as it is made by MB
just use a screwdriver and flat wrench , but have in car always. See owner manual for instructions
Old Jun 23, 2012 | 11:26 AM
KDW4Him's Avatar
I had the local high school metal shop make me one.
syfi
Mar 28, 2026 04:14 PM
smfrycruzr
Jul 17, 2023 05:33 PM
rogerlemoine
Oct 26, 2015 12:02 AM
o55ie18
Oct 5, 2015 05:50 PM
ozkancab
Sep 25, 2015 10:55 AM
