Roadster rear window problem solved?
Old Aug 2, 2018 | 05:35 PM
  #441 (permalink)
Default Re: Roadster rear window problem solved?
Try this link for the answer to many problems.
Old Aug 3, 2018 | 02:02 AM
  #442 (permalink)
georges99's Avatar
Wow, thank you.
Great information.
Old Aug 3, 2018 | 05:42 PM
  #443 (permalink)
Mrmiata's Avatar
Originally Posted by georges99
Thank you for the fast response !
I read in here that I could find instruction to replace it my self. Could you direct me to that instructions ?
Thanks
George
One of our facebook page members who replaced his top has taken the manuals instructions and added some handy footnotes along the way. That PDF is available in our pages files section. https://www.facebook.com/groups/241776609949593/
Old Aug 7, 2018 | 12:41 PM
  #444 (permalink)
georges99's Avatar
Thank you !
Old Aug 7, 2018 | 12:58 PM
  #445 (permalink)
Any direct links to that info?
Old Aug 8, 2018 | 02:12 PM
  #446 (permalink)
djohn14296's Avatar
Talking Re: Roadster rear window problem solved?
Is this a sticky, and I can seem to find it. Duh, yes, computer illiterate. You should always use the kiss principle when dealing with the less fortunate. .
Old Aug 11, 2018 | 10:27 AM
  #447 (permalink)
Victoriasf's Avatar
Hello, I’m having difficulty finding 3M window primer where I live. I have everything else that has been recommended for this job. Is the primer a MUST HAVE, or is there an alternative I can use? Any advice/guidance would be appreciated. Thanks, in advance
Old Aug 11, 2018 | 11:59 AM
  #448 (permalink)
JSK's Avatar
JSK
I believe the primer is a must. I bought it from Amazon when I did it.
Old Aug 11, 2018 | 05:41 PM
  #449 (permalink)
Victoriasf's Avatar
Thanks so much! I spoke to someone who said that the primer was primarily to ensure the surface was clean, to ensure the adhesive would work. I was advised to use alcohol wipes. Have given it a go without the primer and will wait 24 to see what happens. If it doesn’t work, I guess I’ll be doing it all again soon 😀.
Old Aug 11, 2018 | 11:13 PM
  #450 (permalink)
Yea, you will be doing it again. I did it twice without primer, the last time, used primer and it has held so far.
Amazon or NAPA Auto Parts
Old Aug 12, 2018 | 10:12 AM
  #451 (permalink)
Unfortunate that you had to learn the hard way. If we were going to paint some bare wood or metal we would use some primer paint which gives the top coat something to cling to, the same goes for some glues, it needs a secure base to adhere to.
JSK said it was a must but the questioner found it easier to heed the most convenient answer, I guess many of us have done the same at some point.
Old Aug 12, 2018 | 10:27 AM
  #452 (permalink)
djohn14296's Avatar
Question Re: Roadster rear window problem solved?
I was thinking Pizzaguy, yea I know, in my case a dangerous thing. I was thinking of taking maybe 2000/3000 grit sandpaper and lightly roughing the edges where the adhesive will be applied?
it should give the 3M adhesive a better bite, possibly as good as the primer? Just a thought if I can not locate the prime.
Old Aug 25, 2018 | 05:41 AM
  #453 (permalink)
djohn14296's Avatar
Old problem, new question, I have all the necessary products to do the repair, am I reading the sticky correctly about putting the primer on the edge of the canvas? Or just on the edge of the glass?
Old Aug 25, 2018 | 11:35 AM
  #454 (permalink)
Mrmiata's Avatar
Product description---> Primer for windshields to promote urethane adhesion to the windshield.
I only did the glass and now on 3 years of holding..
Old Aug 26, 2018 | 05:02 AM
  #455 (permalink)
djohn14296's Avatar
Thumbs up Re: Roadster rear window problem solved?
Thanks for the response.
Old Sep 12, 2018 | 11:48 AM
  #456 (permalink)
djohn14296's Avatar
Unhappy Re: Roadster rear window problem solved?
Originally Posted by plym69
Hi folks, As some of you regular readers might remember the rear window on our roadster seperated last February and I reglude it with 3M super gasket seal and it is still holding. However I have yet to put the top down for fear it won't hold. Perhaps there may be a more permanent solution.
My wife and I own and operate Morgan Century Farm B&B in the Endless Mountains region of Pa. We cater to car enthusiasts and recently had Joe Richardson and his wife as guests. Joe is Product Development Engineer with the Eastwood Co. I was telling him about the problem that many of us are having with the rear window and as luck would have it he had developed a kit to address this specific problem. It is Item 50007Zp and can be found at Eastwood's web site. Moreover, Joe said he would personally provide phone assistance to any member who would call him at 1-610-705-5462 extension5462. Check it out - it's called Eastwood Convertible Glass Window Rebond Kit.
Should any members wish to tour the Endless Mountains we would enjoy being your hosts. Ken & Linda Florentine Morgan Century Farm B&B 1-888-335-1583 Give us a call and we'll send a brochure.
I went to Eastwoods web site, trying finding this product or kit. Tried using the search function, using both the name, " Eastwood Convertible Glass Window Rebond Kit and the product # 50007Zp. No luck. Tried calling number, no answer?
Old Sep 12, 2018 | 03:13 PM
  #457 (permalink)
Mrmiata's Avatar
2009 post.. not surprising.. even more recently there was a guy "going" to do a frame.. "In progress now" kinda thing.. and then the channel went dead. Ever notice how close the crease is in the canvas under the window when the rear bow raises to the tonoue flaps when all is in motion? You really don't have clearance for a support frame there.
Old Feb 5, 2019 | 11:19 AM
  #458 (permalink)
willnap's Avatar
06 Black on Black. Just curious if most problems are on 05 only, just bought low milage 06 luv it.
Old Feb 5, 2019 | 12:07 PM
  #459 (permalink)
They warrantied some 05s, but fact is, it's all years.
Old Feb 5, 2019 | 12:50 PM
  #460 (permalink)
RED DOG's Avatar
Yes . . . Unfortunately, The rear window adhesive will eventually fail on ALL OEM Crossfire roadster tops. 😠
