Oil Light
Old Oct 9, 2010 | 02:50 AM
oceansideaddict's Avatar
Default Oil Light
Hey Everyone
So I wanted to see if anyone had any experience with this. I got my oil changed at a jiffy lube, and it was good for about 2k miles when I drove to los angeles and back to NM. When I got back, I drove it and the light came on for about 10 miles and then turns off. I took it to jiffy lube and it read right on the stick, I read it electronically and it read OK. Any ideas? Should I just make Jiffy do the oil over again??? Dont wanna blow my motor.
Old Oct 9, 2010 | 03:16 AM
bmorgan's Avatar
Default Re: Oil Light
I did not think that Jiffy Lube carried Mann filters or Mobile1 0W40 for a CrossFire. I would want to confirm what brand (Pennzoil/Quaker State) and weight of oil that they put in there. Also, I would ask if they changed the filter, and what filter (Purolator) they used. I am surprised that they would even know how much oil to put in it.
Old Oct 10, 2010 | 05:06 PM
Yes, Did they charge for 8.5 quarts? That is what it holds.
Old Oct 16, 2010 | 08:46 PM
Thanks for the info guys! I'll have a look into this over the next couple of days. I'll need to check my paperwork for the change. Oil light still on for a good 15min and then goes off if still driving longer than that!
Old Oct 17, 2010 | 07:05 AM
waldig's Avatar
Talking Re: Oil Light
Oil lights are to indicate a low oil pressure situation. You need to change the cheap filter with another to confirm filter and O RINGS are correct. You should do this yourself, easy and Jiffy has blown up cars in va due to the kids that could not make it at mc Donalds !!!! Woody I know this as one of my customers owns a franchise of Jiffy.
Old Oct 17, 2010 | 10:28 AM
bmorgan's Avatar
I would personally not drive the car again until I resolved the oil/filter issue. If you have the oil light on for 15 minutes, it is telling you that you are low on oil. After the engine heats up (15 minutes), the oil may reach the minimum fill mark allowing the light to go off. Not sure that I want to think about what is happening to your engine during those first 15 minutes.
Think about it.... If you check your oil level when the engine is hot, it will read differently than when the engine is cold. Same as with Transmission fluid levels, radiator coolant levels, and even tire air pressure.
Old Oct 17, 2010 | 08:09 PM
im just going to take it into the dealer tomorrow to have the filter replaced. should i make jiffy do the oil again at no cost? or just have the dealer do it?
Old Oct 17, 2010 | 08:52 PM
bmorgan's Avatar
Jiffy lube does not carry the recommended oil for a Crossfire. I would not even consider letiting them touch my car. If you cannot do it yourself (which is what I would recommend), then I would have the dealer do it.
Old Oct 18, 2010 | 03:40 PM
itsky's Avatar
Be careful even with the dealers. I had one try to put in 5W-40 in mine...
Old Oct 18, 2010 | 04:11 PM
jiffy lube destroyed a motor in a van I had....my wife's van, not mine....she thought she was helping me out by getting the oil changed. I didn't even know about it until it was too late....didn't put enough oil in...they use bulk loaders, and if not set correctly or they walk off and don't make sure it all went in, you are screwed....didn't take care of my motor, and it was a 1200 dollar mistake....that was what a Jasper exchange motor cost back in '95...I was lucky, my mechanic did the exchange with my help for 200 bucks...never let idiots change your oil...they hire anyone that can breath work there...I would take my chances at a dealer, goodyear store, or local shop first...
Old Oct 18, 2010 | 10:57 PM
Bladecutter's Avatar
And what exactly is wrong with 5W-40?
If it meets the Mercedes 229.3 or 229.5 specs, NOTHING.
There are more oils that meet the specs that are 5W-40 than there are that are 0W-40.
BC.
Old Oct 18, 2010 | 10:59 PM
itsky's Avatar
BC.
Well, when the dealership lures me in with a "low price", then jacks up the rate and uses different oil, I tend not to be a happy camper.
Old Oct 18, 2010 | 11:15 PM
What did their advertisement promise you, and what did they try to give you?
If it was the Pennzoil European oil, that's a damn good 5W-40.
Most of the testing for it on other forums is showing it's better than the Mobil 1.
BC.
Old Oct 21, 2010 | 04:35 PM
So i went BACK to jiffy and they said everything was fine. I went to the dealer and they want to charge me 97 bucks to diagnose the issue and then another 157 for labor and whatever the part costs are, which he quoted 179 for an oil pressure sensor. ANYONE have an idea on what this might be? hard to change oil pump or oil pressure sensor on your own?
Old Nov 14, 2010 | 03:28 PM
juzmerob's Avatar
I take my 05 roadster to jiffy lube. But, I bring my own oil and filter. They charge me $15, saves time and I know what is going into my car.
Old Nov 14, 2010 | 07:06 PM
Toolman's Avatar
I've done all my own oil changes on my cars since 1992 when Jiffy Lube failed to refill the oil when doing my car. In addition, when I had Penske doing a transmission drain and fill on my chrysler minivan I was lucky to catch and stop them just before they poured in the wrong transmission fluid, so I've been doing the trans fluid changes as well. I undersand that is a bigger job not everyone is in a position to do. It's well worth learning to do the oil change on our Crossfires.
With Jiffy Lube I would be concerned they installed the filter or o rings incorrectly or used the wrong oil.
Old Nov 14, 2010 | 10:52 PM
CrossfireLTD's Avatar
Cool Re: Oil Light
Waldig is correct....I would not take my push lawn mower to Jiffy Lube. Best thing to do in the future is change it yourself or take it to the dealer.
Old Nov 15, 2010 | 02:12 PM
Goldwing's Avatar
I don't think there is a whole heck of a lot of difference between Mobil1 0W- vs 5W-40, unless you live where it gets REAL COLD. I tend to use a mix of 0W-30 (which I can buy in 5 qt containers) and the rest 0W-40. Since I don't drive either Crossfire in the winter, I don't have to worry about real thick oil. On the other hand, I drive my A6 2.7T (bi-turbo) extensively in the winter and always use 0W-40. It's worked for 178k so far. The only real difference between most of the synthetics is their marketing campaigns. They are all going to work the same in your engine.
PNA
Nov 12, 2020 04:44 PM
4drturbo
Jan 3, 2019 02:46 PM
sittininthesun
Aug 24, 2015 10:47 AM
OLDawg
Aug 9, 2015 07:44 AM
skeet370
Jul 18, 2015 01:02 PM
