Mico Switch Replacement
Old Jan 27, 2011 | 09:36 PM
dkriegh's Avatar
Default Mico Switch Replacement
Does anyone have any experience in removing and replacing the switch in the trunk that tells when the divider is up or down?
Old Jan 27, 2011 | 10:19 PM
Hindin's Avatar
Default Re: Mico Switch Replacement
You'll need to pull two pins that hold the carpet to the bracket, pull with ease with something flat, putty knife etc, then the bracket is held on by two 10 mm nuts on the top of the bracket. A ratcheting wrench works well in this small area. Once that's free you can unplug the wire that goes to the micro switch. Reverse order for installation.
ZERACER
Jul 7, 2020 10:21 PM
massanu
Feb 20, 2019 07:06 PM
northwest_crossfire
May 30, 2016 05:19 PM
blacktouring
Jul 31, 2015 11:50 AM
axnguyen
Jul 21, 2015 11:41 AM
