Rear Spoiler Malfunction
Old Feb 8, 2011 | 10:26 AM
aledkthomas's Avatar
Question Rear Spoiler Malfunction
Hi,
I have a problem with the rear spoiler on my 2005 roadster.
Sometimes it will not reset (go down) when i reduce speed, at the same time the red light on the internal button for the spoiler starts flashing?
I can get around the problem by turning the engine off, then turning it back on, manualy lowering the spoiler (via the button) until i hear a "beep" noise and then the spoiler stays down.
At least it does until i go over the speed limit again!
Is this a common fault or am I special?
any ideas what component is faulty and how to rectify the fault?
Old Feb 8, 2011 | 11:06 AM
patpur's Avatar
Senior Member/Moderator
Default Re: Rear Spoiler malfunction
Look in your owners manual for a BAS/ESP reset. Sorry I no longer have my car or I'd give you the page number. This involves simply turning your front wheels lock to lock, but follow the instructions. My spoiler did the same thing and that reset whatever was wrong.
Old Feb 8, 2011 | 08:33 PM
The Beep's Avatar
If the original battery is still in there, replace it.
Old Feb 8, 2011 | 08:49 PM
Lakeview NY's Avatar
I had some of the same problems when I bought my 05 used. It cost them 600 to replace parts and fix.
Old Feb 10, 2011 | 11:52 AM
blackcrossfire07's Avatar
You poor guy!!! You had to give your crossfire up and settle for a lesser car. Life must really suck for you!
Old Feb 10, 2011 | 12:02 PM
$600 to fix the spoiler?
Sounds to me like the typical "let's change parts until we fix it" type of troubleshooting that is so common these days. No REAL knowledge, just guesses.
This is why I fix stuff on my cars myself. But then, I fix electronic equipment for a living.
If your battery is over 4 years old, maybe over 3 - you might try replacing it. If it's over 4, replace it anyway -you are on borrowed time.
$89.95 at O'Rielly's
Old Feb 10, 2011 | 01:55 PM
patpur's Avatar
Hey at least I'm trying not to brag, I didn't mention what I traded it for.
Old Feb 10, 2011 | 08:31 PM
Bladerunner4114's Avatar
I had the same problem last month--after I shattered my front left caliper (which turned the rotor to sea glass). Destroyed the ABS sensor, which made the car's computer assume I was having a braking emergency--spoiler wouldn't come down, spoiler warning light kept flashing like yours, and of course cruise control went out too (not that I needed cruise control as I limped home at 35mph with no front brakes). Clearly you haven't had a catastrophic hardware failure as I did so yes, per other poster, I'd go for the ABS sensor first. Part was ~$120. Good luck.
Old Feb 10, 2011 | 08:39 PM
patpur's Avatar
let someone run the code first before you go buying parts.
Old Feb 11, 2011 | 11:16 AM
You know I am just teasing you. I am actually very happy for your new addition. Great to see someone's dream come true.
You should be posting pictures of your new baby everyday. You should be bragging!!!!
Old Feb 11, 2011 | 02:35 PM
patpur's Avatar
I know your kidding. I don't want to wear out my welcome here. You guys and this forum and CICCI have been a big part of my life for the past 5 and a half years so its become more than just the car. I don't want to get off on a tangent, lets help this guy get his spoiler fixed.
Old Oct 16, 2012 | 08:55 AM
the.Santorini's Avatar
Default Re: Rear Spoiler Malfunction
140,627 mile mark:
I was sitting in traffic today and I heard the spoiler motor running. It was confusing because I was maybe doing.....3mph? So I looked down and the button light was indeed flashing. I've had no damage or failures elsewhere on the car to trigger this. Also, the battery is less than a year old, and when this occurred, I immediately queried the OBDII for any fault codes...nothing. The car is also reporting 12.4-12.6v from the battery while operating. I did happen to look down at my phone when I turned the car off and saw the voltage to be 11.6v however, after I turned off the car. I'm not sure if that is completely accurate, so I will be checking that with a meter tonight. I will keep you guys posted on how this develops and what I do to fix it. Will also be searching the forum some more.
Edit: After all this, I took the car up to high speed to see if the alarm was triggered like so many others have reported...but not a sound from that.
Old Oct 16, 2012 | 09:08 AM
I found this while looking through the forum. It might be a helpful explination for those who have had this happen and it "cured" itself. I won't know until this evening when it's time to drive home.
Originally Posted by Gwetoe
The spoiler will deploy as a safety precaution if the ESP system detects a large difference in the wheel speed between the front and rear wheels. This could occur as a result of the speed signal malfunction, or could occur if the vehicle is attempting to accelerate on a low friction surface causing the rear wheel to spin. The spoiler will remain deployed and the warning light in the spoiler switch will blink until the vehicle is restarted. IF the spoiler continues to deploy in this fashion below the normal deployment speed, see you authorized dealer.
Old Oct 16, 2012 | 09:33 AM
Mrmiata's Avatar
Now dig one up about "deployed when first started" and I'll have something to work with.. LOL
Old Oct 17, 2012 | 04:34 PM
Originally Posted by the.Santorini
140,627 mile mark:
With all the systems now tied together, I am increasingly concerned with a problem I experienced with my old 99 Olds Intrigue (off and on). A few times when I drove up to my bank drive through window, the accellerator not touched, the engine revved to @ 1500 rpm. Now, I do not profess to know exactly what was causing this to happen, and it did not happen anywhere else when I was driving it, but when it did happen it was unnerving. So, with all the EMI floating around the world, I seriousely wonder if the cars of today are adequately shielded from EMI, and if that could be a source of a lot of out 'gremlins'... Just a thought!
Old Oct 17, 2012 | 04:43 PM
Mrmiata's Avatar
140,627 mile mark:
The alarm reportedly sounds if the spoiler is "not" deployed.. just like me your ready for high speed at all times now..
Lockhouse
Mar 20, 2024 04:50 PM
Reliableron
Oct 17, 2015 10:19 PM
atdavis2
Sep 21, 2015 01:25 PM
RacerXofFL
Sep 15, 2015 05:00 PM
davidc90
Sep 6, 2015 10:37 PM
