Stuck in 1st! Help!
Old Mar 19, 2011 | 04:58 PM
Flamenco2005's Avatar
Exclamation Stuck in 1st! Help!
05, car stuck in 1st will niot go to reverse unless I turn off the car then shift to park then restart. Car out of warranty. Changed the brake light swith thats no it. What else? I am desperate no car for 2 weeks now.
Old Mar 20, 2011 | 01:45 PM
Default Re: Stuck in 1st! Help!
Still in desperate need of help.
Old Mar 20, 2011 | 02:15 PM
Bill F's Avatar
I used search and a number of posts came up on this problem. There may be some solutions here.
Won't shift out of first gear...
Old Mar 22, 2011 | 12:12 PM
Blast Chamber's Avatar
This is a long shot, but a common problem on the automatics is for them to leak fluid from the transmission adapter plug housing. This is the large electrical connector located at the front passenger side of the transmission. According to the following post on a Sprinter forum (Sprinter vans have the same transmission), this plug could also be related to your problem of being stuck in first gear.
Stuck in 1st gear - Sprinter-Forum
If you do have a plug leak your transmission may be low on fluid. Unfortunately Chrysler didn't provide a dipstick and the filler tube is sealed with a locking cap. The good news is the replacement of the leaking adapter plug housing is not all that difficult if you are mechanically inclined. I replaced mine while changing the transmission fluid. You can get all of the parts needed including fluid at the following website....
Transmission Fluid-OEM Fuchs 4 Liters 2002-2011
Finally, here is a link to a great post from waldig describing the replacement of the leaking adapter plug housing....
https://www.crossfireforum.org/forum...-ta-daaaa.html
Hope this helps.
Old Mar 22, 2011 | 01:55 PM
PAULW's Avatar
Can you put the shifter in the drive position? Do you have any warning lights on?
Old Apr 13, 2011 | 01:57 PM
Tried everything I can think of. Payed of the 1st mechsanic $1500 still screwed up. Dealer has it now. replaced igintion section payed $1820 they said they tested it and drove it all weas fine I get there to pick it up and it is still fu--ed up. I pay all that money and I am still at square one. even after replacing the gear shift assembley. When I ask where is the old one they look at me and said Uhhhhh we threw it out. I am ready to torch the damn thing.
Old Apr 13, 2011 | 04:29 PM
blackcrossfire07's Avatar
Do a search on this forum... I could swear I have seen this issue on here before with a solution to your problem.
Old Apr 13, 2011 | 04:50 PM
Angry Re: Stuck in 1st! Help!
Its out of my hands now. I went to all ofem. None was any help. Only one had the exact same problem, and she never replied.
Old Apr 13, 2011 | 05:02 PM
damn dealerships....first would check fluid level, the sensors in these cars, well, they are sensitive...next, Throttle Control Module, if not low on fluid, or connections are shorted, etc. There is a temperature sensor on the tranny as well, as well as a pressure sensor. All must be working, correct voltage and all. Most of the time this will be cause by a bad connection, or low fluid.
Old Apr 13, 2011 | 05:21 PM
TiredRetired's Avatar
Our of curiosity, does your 05 still have the original battery? It it has a white top, that indicates it is original. Batteries that are starting to go south can cause a lot of weird problems with these cars, that is why it is best just to change them out every few years to avoid being left in the lurch.
Certainly a lot cheaper to replace the battery than some of these expensive components, like the shifter assembly.
Did they get any transmission codes during your two repair cycles? This would be from the TCM or Throttle Control Module.
You could be in limp mode, however, I am not sure that when that happens if codes are generated. A reputable dealer should be able to figure this out.
Finally, yarn on that dealer that charged you 1800 Somolies for nothing. Sheesh. Good luck and keep us posted.
Old Nov 14, 2018 | 08:43 PM
Jlogan123's Avatar
hey buddy did you ever figure out the problem my crossfire is stuck in 1st gear also and won’t go into reverse unless the car is turned off and restarted. Thanks
Old Nov 14, 2018 | 10:13 PM
This thread is 7-1/2 years old....might not get the answer you are looking for here
Old Nov 14, 2018 | 11:50 PM
Your transmission has a fault, to prevent damage and to keep you moving the car goes into what is called ‘Limp Mode’.
The fault probably lies in one of the plates at the bottom of the transmission, get the trouble codes read and see if they point to a particular problem.
deerhunter
Jan 16, 2021 10:56 AM
jimf
Oct 10, 2015 10:22 AM
Calitony
Sep 24, 2015 12:53 PM
PA/XFIRE
Sep 5, 2015 01:25 PM
Crossfireone
23
Aug 25, 2015 04:56 AM
