Agh! ABS, BAS and ESP Light On and Spoiler Won't Go Down!
Old Dec 31, 2017 | 09:28 AM
  #41 (permalink)
EEPS69's Avatar
Angry Aloha from Hawaii! I need help !
So im driving down the road and every light comes on and the speedometer drops to 0 mph even though the car is still running and moving forward and can accelerate. I get home just fine...shut her down and then it wont start again and the spoiler is up and all lights are on.....any suggestions? Ive heard wheel speed sensor as well as some sort of module. I love this car but dang!
Old Dec 31, 2017 | 10:03 AM
  #42 (permalink)
Default Re: Agh! ABS, BAS and ESP Light On and Spoiler Won't Go Down!
Start with the RCM module.
Send an email to tighed1@hotmail.com, he can fix it for you.
Old Dec 31, 2017 | 10:14 AM
  #43 (permalink)
Default Re: Aloha from Hawaii! I need help !
There are many ways it will not start, the engine is turned over by the starter or it does not turnover when using the starter, which is it?
How many miles on this car?
Any codes set?
Need more info as there are many causes as with all cars.
Old Dec 31, 2017 | 11:52 AM
  #44 (permalink)
Yea, does the starter engage but the car still won't start - or do you not even get starter engagement?
If you get no starter engagement, then yank the RCM and follow George's advice.
If you get starter engagement, well, we may have some real homework to do here.
The fact the car kept running makes me think the RCM is NOT the issue, but until you tell me if you have stater engagement, I can't help, that clue is VERY important.
It seems to me someone else experienced this VERY symptom in the past, oh, year or so. Dave? GEorge? Do you guys remember that? I'm sure the thread would be in one of the technical forums here... I swear someone spoke of "the dash lit up, speedo went to zero, but the car kept running fine..." I am thinking it was resolved, and I remember thinking "Im gonna remember this." But I don't remember the fix, just that it happened.
Old Dec 31, 2017 | 05:49 PM
  #45 (permalink)
tighed1's Avatar
I've repaired a few RCMs with those exact symptoms. Turns out it was a bad traction control relay. Still haven't looked to see how it possibly affects the speedo.
Weird.
  • Car will start and run with bad traction control relay. Wing will be up and ABS/ESP lights will be on, possible no speedo operation.
  • Car will crank but not start with bad fuel relay (really!).
  • Car will not crank or start with bad engine control relay. With key in the ON position, wait, the radiator fan will spin VERY fast.
  • Car will start and run with bad air pump relay but will throw a CEL and PO410 code.
  • Car will start and run with a bad horn relay. Horn will not work!
Old Jun 14, 2018 | 12:00 PM
  #46 (permalink)
Nb78680's Avatar
Lightbulb Re: Agh! ABS, BAS and ESP Light On and Spoiler Won't Go Down!
Originally Posted by Mike1118
No I'm not a dealer. He did say his battery is over 7years old. I'm guessing even if this isn't his problem today it will be tomorrow. I see where a few different members advised the same thing. To be honest, I know very little about these cats. Changing the battery would be my guess for about everything to do with these cars. Oh I just changed my battery the other day. It didn't cure my problem either. So I did the other fix. Black tape over the low water light.
Has anyone thought about checking the battery amps. Have a John Deere Gator, wouldn't start even though the voltage was over 12, but not enough amps. Just a thought.
Old Jun 14, 2018 | 02:10 PM
  #47 (permalink)
The post is six years old, but since you asked: Yes. It's a dead end.
Load testing the battery is not a valid test for this scenario. It appears that the car's electronics are sensitive to the poorer capacitive reactance of an aged battery. The battery will test fine insofar as capability to provide amperage, it just does not filter well.
There is another reason to not run a battery more than four years old in these cars - the poorer filtering capacity of an older battery can cost you. I preach "change the battery at four years". But on my current SE, I let it go almost five. One evening, putting the top up, system voltage glitched, now I need an airbag module.
I guess that even I don't listen to me....
wootto
U.K.
Aug 16, 2020 07:55 PM
Hoppy
Dec 7, 2018 07:36 AM
northwest_crossfire
May 30, 2016 05:19 PM
srtmodder
Jul 29, 2015 05:12 PM
Blackout317
Jul 7, 2015 08:38 PM
