Oil Level Sensor/Hood Strut
Oil level sensor is bad, dealer wants $523.00 to replace and it is NOT covered under my service contract. This is such a ripoff . Fortunately I can drive the car without replacing as long as I check the oil level between iol changes.
Also, hood strut is bad and they want $295.00 to replace that, another ripoff! Think I will just stick with a big broom stick! Any ideas or suggestions on either of these?
Many thanks!
Many thanks!
Re: Oil Level Sensor/Hood Strut
hood strut :
oil level sensor : 2005 CHRYSLER CROSSFIRE Oil Level Sensor
CHRYSLER Crossfire 2004 2005 2006 2007 2008 Hood Lift Support, Strut. Qty (1) Stabilus OEM : Amazon.com : Automotive
Replacement hood support . . . Same guy recommended by ALA_XFIRE but it is less expensive to buy from his E-Bay listing. I have bought MANY lift pistons from Mr Lou . . . Good guy and good products!
Chrysler Crossfire 2004 2005 2006 2007 2008 Hood Lift Support Qty 1 Supports | eBay
This is a ten minute install job . . .
on
Many thanks!
Many thanks!
1) Extended warranty's and service contracts on cars are usually worthless.
2) Taking a Crossfire to a Chrysler dealer is almost never a good idea.
Now, if we could only spread the word before the damage is done...
on
on
Carl, put the hood up, press the (upper) button on the shock and push the hood up to vertical.
Press the other (lower) button on the shock to lower it.
Last edited by pizzaguy; 02-11-2014 at 07:21 PM. Reason: edited for accuracy and your reading enjoyment :)
on
Mark. I knew you would know... I really appreciate everyone's help...
BTW. Getting anxious about "April" GTG..
Remember to "Keep on Crossfireing"
Many thanks!
Many thanks!
Stealerships are not in the business of REPAIR. They are in the business of REPLACEMENT. They don't repair anything! They'll always suggest that everything needs "replacing" before the can "fix" anything. Which is why they're not called mechanics - they're called technicians.
Never go to the stealership. Come here first! Our guys are more capable and experienced than any "stealership" in the world. BAR NONE!
on
Always remember this:
Many thanks!
Many thanks!
great write up on oil sensor replacement by JerryG
https://www.crossfireforum.org/forum...el-sensor.html
Had the oil level sensor replaced by the dealer on my car. Went out the next morning and there was about two quarts on the ground underneath the car. Tech had cracked the pan when he replaced it. So I got a new oil pan as well. The whole thing was covered under my extended warranty.
The hood strut can be found here for $40 or so. Over there I can only guess. Put Hood Strut in search and you come up with rhe number pretty quick. Do not buy it from a Chrysler dealer, try a Mercedes dealer if they will talk to you. Use the makers part number if you can to save money.
FYI: bought one from Parts Geek, last year. OEM, good price, as I recall. (hood/bonnet strut, Note: $20 +/- ones are probably for the trunk/boot. I'm trying to be bilingual; LOL!
Check out BMA auto parts; they have hood struts & a lot of other cool parts. Amazon uses this supplier.
